Raypak versa II pilot light on heater does not go on. Choice of heating range for pool and one for spa. Last year the pool dial stopped working. This year none is working.
  • grfisher1 Jul 18, 2008
    raypak versa II pilot light on heater does not go on.
shuggie73
SOURCE: Laars lite II Pool and spa Heater LG model
Bad pilot generator? Flow issue?
Posted on May 25, 2009
  • 864 Answers
SOURCE: raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
Posted on May 30, 2009
johnsonr1
  • 91 Answers
SOURCE: pool heater wont fire up
Its just after 1 am here as well, Ontario Canada. Yes, you have to remove the front lower panel by raising it then pulling out at the bottom. Then compare the valve you have with the 2 in the picture on pg 5. If it is easier, you can have your husband call me while doing this and I can talk him through it. My contact information is located on the main page of my company website www.emshvac.com
Thanks
Richard
Posted on Jun 23, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Our Raypak pool heater is 14 yrs old. This year
What you probably need, you may be able to install yourself and save some$$$. It's call a thermocouple. It's a long thin tube that has a probe bulb at one end and snakes it's way back to the gas regulator.14 years is plenty of service to get from one of these.Don't laugh, but often times you can find a good one on anold gas heater in the metal pile of your local dump. It's worth a peek. If not get one of your heat and cool contractor friends drunk, then ask him to pick one up at the gas company. Town laws vary greatly from town to town. Here in Provincetown we can hardly change a light bulb without a permit...lol. Good luck, I have faith in you. Thanks Dana.
Posted on Aug 21, 2009
john224
  • 1378 Answers
SOURCE: Raypak pool heater
Is it a cartridge filter? If so, get a new element.
Posted on Aug 31, 2009
How can I convert a Raypak B55MP 55K BTU spa heater from propane to natural gas?
You would need to change the gas valve and the orifice in the pilot assembly.
Jul 19, 2011 | Raypak Versa 55k Btu Natural Gas Millivolt...
Versa 130,000 will not ignite spark works but will not ignite
You might have debris in the pilot orifice which is just below the pilot spark/light. Also might be a gas valve issue. Is the gas valve set to on? I would clean the pilot orifice first. Good luck.
Jun 19, 2010 | Raypak Versa 130,000 Btu Above Ground...
Raypak pool heater
Aug 30, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a versa gas heater for my above ground swimming pool. This year the pilot will not light. It gets hot but will not ignite. Any ideas what could be wrong?
I have often found spiders or other **** nesting in the pilot tubes of these boilers which blocks the flow of gas. You will either need to have it professionally serviced or you can attempt to do it yourself, which I do not recommend.
Jul 11, 2009 | Raypak Versa 130,000 Btu Above Ground...
Pilot lights but burner will not fire
what burner where on the oven or the cooktop, if its the oven it may need new gas valve w\ thermocoupler
Jul 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Where is the pilot light on Raypak versa pool heater, i need to light it manually?
In side the front on the lower right is a long 3/8" wide tube about 5 inches long...you'll need a special lighter with an extended wick.
May 18, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak Pool Heater
check to see if ignitor is lighting if so check gas line to ignitor if no ignitor replace and check safety circuit
Nov 05, 2008 | Raypak DOOR ASSEMBLY
Heating & Cooling Logo
210 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
