Question about MTX Thunder5601 300W x 1 Car Amp Mono Subwoofer Amps Car Audio Amplifier
Thunder 5604 ok so i jsut got this amp and system form my brother...and i have it hooked up the same as i had my old on hooked up and now i know it turns on but wont put out sound like i have the power hooked up ground is hooked up right...ummm...rem hooked up rca cable things hooked up i justcant get sound to come out
    Problem Solver:
  • 30 Answers
Okay u will have to troubleshoo the amp.....dose the amp light up?...when u have the radio on? also check your sub wires.going to the amp....make sure the rca'sare hooked up to the radio rear out puts are the radio sub out puts...and then test your amp gain adjustment...let me know if that work's
Posted on Jun 23, 2008
What other MTX Thunder amplifier can i hook up with a MTX Thunder 6152 amplifier??
Not sure what you are trying to do, but you don't hook up one amplifier to another. You can pick any brand or model amp to drive other speakers than the ones that you are driving with the 6152. Just consider the power needed to push the speakers at the impedance they are rated(and hooked up)at. Look at the owners manual to determine if you need another amp. Hope that helps a little.
Apr 16, 2014 | Car Audio & Video
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
Can i bridge this hifonics amp
If you don't know if the amp is bridgeable, then I wouldnt do it. It could already be bridged internally and bridgeing it through the speaker terminals could be disatrous, i.e. the infamous blue smoke of death. The amp looks like a 2 channel amp fromt he pic and you have two speakers you are trying to power with it. So the safest bet would be to just unbridge your speakers and hook them each up to the amp as normal. No blue smoke. Good luck!
Feb 18, 2010 | MTX Thunder 801D Car Audio Amplifier
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
I have a thunder 5604 and all of the suden the short light came on and stop working, i disconect it and , put it back but th light still on an no sound. it doesnt smell like burn, im a mechanic and...
theres a few possible issues pull and replace all of the fuses also use atleast 4 ga power and ground wires if ur ga is 6 or up get a new amp kit i know my protect mode goes on when the ground isnt connected if none of that works take it to the company you got it from and have them check out the internals
Jun 17, 2009 | MTX Thunder5601 300W x 1 Car Amp Mono...
Mtx thunder 1500 watt amp no sound
Even if there is no visible damage, it could be that one of the transistors is blown, Use a multimeter to check the resistance of the transistors.
Apr 09, 2009 | MTX Thunder 1501D Car Audio Amplifier
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
MTX Thunder5601 300W x 1 Car Amp Mono Subwoofer Amps Car Audio Amplifier Logo
255 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
