Question about Radio Communications
Call We have 4 radios that we use how do we set them up to be able to call them all at once without speaking hey are you on there?
  • Radio Commun... Master
  • 1,654 Answers
Not certain I understand your question. If you radios have a call-alert feature, it will buzz or ring the other radios when you press the PTT on your radio. If the radios do not have call alert, you will have to transmit a spoken word to get the others attention.
Posted on Jun 24, 2008
Hey guys i got a cobra 29 classic pushing a grey 150 bi linear the radio has been tuned and peaked and was told it was set to push amp fine however when i key up i get a humming noise what needs adjusting...
I suspect it is a ground issue it is hard to say. But I have lots of question. Is gauge wire large enough? Power source? Wires and coax laying across or parallel? If it has been peeked turn mic gain down and see if it helps. If you are using it with a external speak, key it away from speaker. Good luck give your radio man as much info as possible a good one will not want discouraged customer.
May 27, 2014 | Radio Communications
How do i get the radio back to factory settings
In order to Get the RADIO back to factory default settings,all you have to do is,If you have a NEW RADIO,read it,by using the software/programming cable,and write it in your old radio,
Thank you,
Jack
Jan 27, 2013 | Radio Communications
Cannot hear my voice in the headset when speaking
Been a long time since I used a head set but never heard my own voice through it when speaking.
Jun 03, 2017 | Creative Labs HS-600 Headset
Change language setting motorola mv22
Hold in the PTT button while turning on the radio. First it will announce the frequency, then press the monitor button once, then it will announce the code, press the monitor button one time again, then if it is equipped with a language choice, you will get to select your language by using the PTT button to walk through the choices, lock in your choice by pressing the monitor button one time. Shut the radio off, then back on without holding in any buttons... you are ready to use the radio.
Best regards.
Apr 23, 2012 | Motorola MV22CVS VHF (2 Channels) 2-Way...
Good day, I bought a Kenwood DNX6160. I do not
Hey, Gisele did you ever get this problem fixed?
Thanks,
John
jmhanna28@hotmail.com
Dec 21, 2010 | Kenwood Dnx-6160 GPS Receiver
How do i calibrate an Aries swr 420 meter for a cb radio
To calibrate the meter set the switch to FWD/CAL/REF and key the microphone without speaking into it. then turn the control until the needle is on CAL. Unkey the mic, set the switch to SWR and then key the mic to read the SWR.
Thanks,
Dodgem250.com
Apr 16, 2010 | Radio Communications
Problem with the talking.
Not sure what model/make you've got but what you describe is called the VOX feature. This normally needs to be turned on or will activate automatically if a headset/mic is plugged in. How it works is that the mic will pick up initial noise of you speaking and make the connection. Normally it can be set to turn off after a period of silence.. But as I said, without knowing the make or model I don't know if your radio has this feature or if it's a fault.
Oct 06, 2009 | Radio Communications
How do I set my sx700 radio to work with hands-free headsets? Any assistance would be appreciated.
Hands-Free Use With Accessories (VOX)
You can transmit hands-free with the use of optional accessories. Once
VOX is turned on, the radio detects your voice and transmits when you
speak.
1. Turn the radio off and plug the VOX accessory into the accessory
port.
2. Turn the radio on. VOX shows on the display.
3. Adjust the volume appropriately by rotating the volume knob . Lower the volume
before placing the accessory on your head or in your ear.
4. To turn off, simply remove accessory.
Note: There is a short delay between the time you start talking and
when the radio transmits. There is a short delay before the
transmission is completed.
Owners Manual: http://www.motorola.com/mdirect/manuals/SX700_userguide.pdf
You must be using a VOX capable accessory. Generally this is an accessory without an in-line PTT.
Dec 03, 2008 | Motorola Talkabout SX700 2-Way Radio
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
Radio
Both of these applications work with GPRS (assuming you are talking about Internet radio). and GPRS settings are service provider specific. therefore the solution would be to speak to Virgin customer care and ask them to send settings for GPRS. They would send you a 'service message' which you can save as default settings and the problem should solve.
Do let me know once the problem is solved..
take care
Jun 24, 2008 | Sony Ericsson Walkman® W880i Cellular...
Radio Communications Logo
52 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
