Hd antennas How do i hook up my philips digital amplifier. Indoor Antenna product number phdtv3?
What can I hook up to this tv to get basic channels. Not cable?
Depending on your location and distance from the available broadcast outlets, you may be able to receive basic commercial broadcast channels using a simple inside or outside ad-on antenna, available from most electronic retail stores or on line vendors such as Amazon, Ebay, Best Buy, etc.
Jul 16, 2015 | Televison & Video
Had my channelmaster 4046 HD hooked up to a vizio tv and got all major channels. Now have hooked up my antenna to an RCA tv and can't get NBC and local FOX station is jumpy
The tuner in the RCA has poor sensitivity. Radio Shack sells a inline amplifier that may help, make sure you can return it if it doesn't. Move the antenna outside if possible and as high as possible, that may help. Good Luck!
Feb 14, 2014 | Channel Master CM-4046HD MODERNtenna...
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
Trying to set up Pioneer 5080 HD for use with NO CABLE. Digital amplified indoor antenna? I don't have the owners manual or the remote.
good luck as almost impossible without the remote to do much with this set, the manual you might be able to google.
Sep 03, 2012 | Pioneer PDP-5080HD 50 in. Plasma HDTV
How do i get hd channels with no cable ? just antenna
If your TV has a digital tuner, you can get any HD channels if you use the correct antenna pointed at the transmitter and are close enough to the transmitters. (Antennas labeled as HD are not always appropriate for your location.) Your TV will downgrade the signal to 480i if the TV can't support a 720p or 1080i resolution.
First where do you live? Use antennaweb.org or tvfool.com to determine the correct placement of your antenna for your area/stations. AntennaWeb uses a very conservative signal strength calculation despite assuming an external antenna. Tvfool will give the antenna color rating which is also provided on the antenna package. When properly installed (with no trees or hills blocking the signal), the matching antenna should receive the listed channel.
If you use a splitter to share the signal with several TVs, you may need an amplifier to bring the signal strength to that needed for the tuner to interpret the digital signal. (Note: amplifiers and splitters can fail and the amplifier may become a signal filter blocking the signal; test the antenna strength on a direct connection if there is a problem.)
If you do not have a digital tuner in the TV, you may have gotten an SD digital to analog converter. These are the more common (and available with the government coupon) converters. You will need to get an HD capable tuner to see the full HD signal.
Please add a comment with your TV model and antenna choice for additional support.
(antennaweb indicates that my external antenna should only get the stations 10 miles away. We actually receive the channels from 30 miles away. We use an amplifier splitter to feed the signal to several TVs. I set up two indoor antennas for a neighbor's TVs. One gets the signals from the transmitters 30 miles away and the other from the transmitter 10 miles away. Both get HD from the stations with HD broadcast (not all channels are in HD here). The difference is totally due to antenna placement.)
Aug 10, 2012 | Hisense Televison & Video
Tried to hook up a HD antenna but it won't work
HD is pretty critical and if a indoor antenna do not expect much or anything for that matter.
Jun 17, 2012 | Televison & Video
HDTV unable to get HD Channels w/ Antenna
The problem could be your antenna. Many people will buy small indoor tv antennas and wonder why they're not getting the signal that they want or the channels that they expect. Its not your fault. Digital signal is in two formats: UHF AND VHF. Some antennas only receive UHF. But many of the low band channels are VHF, so 1) you need an antenna that will receive those signals and 2) you need to know how and where to install that antenna and 3) you need to know if you need a signal amplifier depending on your coaxial cable length and number of connections. I recommend visiting dennys antenna service (no I don't work there and I have never purchased anything from that website. He just has an excellent informational article with a great deal of "how to" on his pages.). http://www.dennysantennaservice.com/2029710.html This should be of great help to you. Happy viewing =)
Dec 26, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
May 27, 2009 | Philips Televison & Video
I have a tb110mw9 converter "not getting all my channels"
if your channel was fuzzy in analog then you will not get it in digital because digital is pretty much all or nothing. I would try a an antenna with longer signal range.
Feb 20, 2009 | Insignia Digital-to-Analog Converter for...
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
