Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1997 1200 custom
Speedo just stopped working. I changed the speedo and still nothing. all lights and milage still comes on. The red white and black wire running to sending unit have no power
I had the same problem w/ my 98 wide glide.changed speed sensor on top of transmission and solved the problem
Posted on Jul 27, 2008
    President:
  • 357 Answers
Hi there
The cables which go to your Speedo might be faulty. Try replacing the cables and see if that helps at all.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 27, 2008
I purchased the Legrand RT1 Time Switch to run a bathroom fan. It is installed and I see indicator lights. Every time I turn the fan on, it runs for a second and stops (hearing clicking in the switch);...
You connected red and white wires together.
No problem, nothing burned out, and it's simple to fix. Steps below.
RT1 is electronic countdown timer, and electronic timer clock inside needs separate circuit, just like your alarm clock needs to be plugged in. >> that's why timer has white wire. White wire completes circuit to timer clock.
Manual says:
Timer-black-wire to Hot; Timer-red-wire to Load (lights)
Timer-white-wire to Neutral.
Heres what to do
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push countdown button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 27, 2010 | Pass & Seymour / Legrand RT1-W 10-20-30-60...
My speedometer on my 2000 xl883c quit working.
sorry but the speedo head needs replacing, they can be opened up but its fidlly and could still be u/s
Jun 29, 2010 | 2004 Harley Davidson XL 883C Sportster...
Moved into house. Craftsman Garage Door Opener Model 139 18052 not working. Trolley won't move away from stop, chain loose, wires were not connected. Connected black to black port, red to red port, one...
YOU WILL NEED TO UNPLUG THE UNIT AND TAKE OFF THE COVER.
ROTATE THE MOTOR BY HAND UNTIL IT BACKS OFF FROM THE STOP - WHEN IT IS JAMMED NOTHING WILL WORK.
YOU SHOULD HAVE 2 WIRES WITH BLACK TRACE ON THEM 3 WHITE AND 1 RED TRACE.
YOU HAVE THE COLOR CODES RIGHT.
YOU CAN GO TO LIFTMASTER.COM AND DOWNLOAD A MANUAL FOR A SIMILAR UNIT - THEY MAKE THE CRAFTSMAN BUT USE A TOTALLY DIFFERENT MODEL # SYSTEM
HOPE THIS HELPS
Apr 30, 2010 | liftmaster Chamberlain Garage Door Opener...
Help wiring up digital speedo to a 2004 dyna sport.
Hi Larry, I would give the nice folks at Diamond Digital a call. Good luck
May 26, 2009 | 2004 Harley Davidson FXD - FXDI Dyna Super...
Speedo sometimes failed to work
I had this exact problem on my old focus. Its nothing to worry about and its not expensive. Your car has a speed senser underneath the gearbox and a common fault on these cars is for the gearbox to slightly drip oil. When the oil drips it drips right on top of the senser and blocks the speed readings.
The good thing about this is your milage on your car wont go up when the speedo stops working, so when you come to sell it!!!!!!! you get my point.
to fix this problem it cost about £20 if you do it yourself.
Feb 18, 2009 | 2000 Ford Focus
Photoelectric Control (Photo Eye), dawn to dusk, install
Connectthe SUPPLY wire (Black) to the Photoelectric Black. ALL of the white wires - to lights and from supply and on PE - connect together
Redfrom PE goes to all light fixture black lines
Nov 24, 2008 | Electrical Supplies
MSI starcam 370i only shows black and white
You can change your lighting to fluorescent lighting the brighter the fluorescent lights are the better your cam will show up the colours, it worked for me.
Aug 02, 2008 | MSI Starcam 370i Webcam
Lands Phones Logo
99 people viewed this question
Top Harley Davidson Lands Phones Experts
Brian Mathews
Level 1 Expert
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
