Question about Canon PIXMA iP1800 InkJet Photo Printer
Pixma 1880, 4 orange bliks and 1 green
What is this blinks for?
i have already download teh resetter software from teh net but when i run the software, i cannot read teh printer. it blinks 4 times orange and 1 time green. please help
  • Anonymous Jul 05, 2008
    how can i solve my problem regarding my printer canon 1880
  • Anonymous Jul 08, 2008
    My Cannon printer blinks 7 times orange and 1 time green. please help
When it blinks 4 times orange it means that your ink has run out. You should replace the ink cartridge.
Posted on Jul 06, 2008
Canon pixma ip 1880 stop print
If there is no bad sound in your printer, you may need to replace your ink cartridge of reset your printer.
Thank you
May 25, 2013 | Office Equipment & Supplies
Error 6000
This is the error code printer Canon IP1200, IP1300, etc. light blink Indicator:
3x orange 1x Green = mechanical error
if you dont have any knowlegde about printers, better bring your printer to Canon service center.
4x orange 1x green = printer absorber full
reset your printer using software ressetter or try using manual reset. different printers have different manual reset.
5x orange 1x green = black cartridge/color cartridge error
can be chip error or connector is dirty.
7x orange 1x green = black cartridge/color cartridge error
8x orange 1x green = printer absorber full
12x - 17x orange 1x green = cartridge detection error
How to Reset waste ink counter Manually 1. Unplug power and USB cable. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button.
How to Reset waste ink counter using Resetter
1. Download software for Canon iP1200 printer. DOWNLOAD 2. Unzip downloaded file to any location using, 7ZIp, WinRAR, Winzip, etc 3. Run GeneralTool.exe 4. select connected USB port number from USB port 5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION 6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. the selected waste ink counter will be reset.
Thank you for posting. Hope this helps.
Jul 06, 2011 | Canon PIXMA iP1200 Photo Printer
THE INK ABSORVER IS FULL
Resetter canon iP 1700 and iP1300
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1700, iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1700, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal
Step 2 : Using software resetter
  1. Download Software Resetter for Canon Printers iP1300 dan iP1700 Software Resetter for Canon Pixma iP1300, iP1700
  2. Ekstrak/Unrar/Unzip the Software
  3. run GeneralTool.exe
  4. Select USB Port where the canon ip1300 or canon ip1700 installed.
  5. CLick Lock Release button
  6. Select EEPROM CLEAR
  7. Click Test Pattern 1 button
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal.
Resetting Ink-Waste Ov
Nov 27, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
ERROR 5B00 IP2770
How to Reset printer canon ip2770 (E 5B00) ip2770.jpegIP2770 Resetter v1074 I have tried. IP2770 Resetter was sent by our friends in Jambi, and hopefully this iP2770 Resetter runs perfectly. Resetter is free passwords ... and FREE
How to Reset Canon IP2770 Error 5B00
Download Canon iP2770 Restter v1074 free pass Here
(Do not forget to turn off the download manager, for a successful download)
Go to the iP2770 Service Mode:
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (Do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
V1074 iP2770 Resetter Then run it:
1. Prepare 2 blank paper in the printer
2. In the menu "Clear Ink Counter" click "Play" and "Platen"
3. Click Test Print ... Done ...
(In some experiments sometimes "platen" unable / err message appears, but no problem, still can work well)
Hopefully Successfully
Nov 26, 2010 | Canon Office Equipment & Supplies
How to download software for cannon pixma 1880 .
you may use google as your search engine in searching for the correct driver of your printer. be sure to type the exact model of your printer.
May 10, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Ip 1880. green and orange light blink alternately but green stays longer at the third blink.cartridge also not moving. please help me.
try to reset ur printer. first off ur printer and take off the jack,just hold the grin light then plug the jack,and also hold the red light den move your fingers in the grin and red light
Feb 01, 2010 | Canon PIXMA iP1800 Printer
Where is the waste ink
You're probably referring to the Waste Ink Tank in a Canon printer. If you've received the Waste Ink Tank nearly full message, there's a workaround.
The waste ink absorber is actually a pad/sponge that absorbs left over ink spray. There's really no precise way to measure the amount of ink these pads hold so when the message first appears, "waste ink absorber is almost full" it's just an estimate.
The workaround for the message is as follows:
Reset ip2000 / 3000
1. Turn off printer
7. Press the Power button and the printer should turn off, if not,
8. Your printer should respond as normal.
Using the above procedure should clear the message and your printer should function normally afterward. Best of luck and thanks for using Fixya!
Greg
Nov 26, 2009 | Office Equipment & Supplies
How to reset my printer canon ip 1880.thanks
If you ask for reset of ink levels you can't.You need to turn off the function on printer to show the ink level.On most printers this happen with push resume button and hold it for 5 seconds.The printer shows empty cartridges but it will printing.
If you ask for waste ink tank reset follow this:
  1. Press power button while plug in the power cord – green lamp.
  2. While hold the power button press resume button twice – orange blink and return to green.
  3. Release the power button, Then the PC will recognize new printer install.
  4. You need the software for permanent reset.
  5. Run the software and select printer port.
  6. Then select Set Destination
  7. Click MAIN and PLATEN button to reset waste ink counter to zero.
  8. Finally test print by click TEST PATTERN button.
Oct 19, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
The ink absorber is full for pixma 1880
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jan 15, 2008 | Office Equipment & Supplies
Canon PIXMA  iP1800 InkJet Photo Printer Logo
413 people viewed this question
old marine
old marine
