Question about LG VX9400 Cellular Phone
End Call / Power Button not Working
I had another 9400 that broke, so i just took it to the store and got it replaced, but probably 3-4 hours after i got the new one, the end call button is not working at all. anyone got anything?
Mine does that too!
i just take out the battery, turn it on and off, idk mine turns off randomly sometimes too :(
Posted on Jul 08, 2008
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
I have no power to my Dell Inspiron 9400. I am using a power adaptor whicih I have verified to be workign correctly. I have held the power button down for more than 20 secs, but there is no indication of...
Hello, Rick.
The most common reasons are the battery, power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Also, power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
Hope this helps.
Jan 23, 2011 | Dell Inspiron 9400 Notebook
My Dell inspiron 9400 wont charged my battery. Both the charger and battery are new
try to charge the battery while the computer is off for 3 hours. if that does not work, remove the battery from the computer and turn on the computer using only the ac adapter. if the computer is working fine using only the ac adapter, call your computer manufacturer for possible battery replacement
Jun 11, 2010 | Dell Inspiron 9400 Notebook
Lt 1042 will not trun over
Check the compression release. See this video to tell whether it's working or not.
May 15, 2010 | Garden
I have a dell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the dvd player light comes on and about 3 seconds it turns off. Does it with and...
It shows no power on your laptop but it shows you the dvd player led comes on then off. I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well. 2. Make sure AC Adapter is not yet connected to the laptop. Press and hold on the laptop's power button for 10 seconds to drain the power flea. 3. Connect the AC Adapter to a known good power outlet, check AC Adapter power LED if it is on. Try to sense if AC Adapter is not making a bit of noise when it is plugin to the wall power outlet. 4. Connect now the AC Adapter to the laptop. Check if AC Adapter LED stays on when it is connected to the laptop. If the LED stays on means the AC Adapter is fine. If the AC Adapter LED turned off check the AC Adapter pin that goes to the laptop AC socket if it is loose. 5. If AC Adapter stays on after connecting to the laptop try to power on laptop. If no power LED comes on then this is motherboard problem. 6. Before replacing the motherboard there is one checking needs to do. If you can open your laptop bottom part then good, do this when laptop is not connected to any power source. Try to reseat the laptop CMOS battery then try to power on laptop after, if still fails then replace motherboard. I hope this helps.
Dec 12, 2009 | Dell Inspiron 9400 Notebook
Dell inspririon 9400 wont start
(before you do anything remove the battery and th ac plug)remove the memory inside small door on the backside that has a "M" on it now once you remove the memory install the battery, power on if you hear a couple of beep tones you are half way there the motherboard is good so the problem is what you took out so there are two memory slot try them in the A slot one at a time.If the problem is memory replace it.
Good luck
Aug 29, 2009 | Dell Inspiron 9400 Notebook
Replace the cable traction (part #105-1844)
I just replaced mine and it was a little difficult and took me roughly an hour to do. First, download the walk behind power mover drive systems at https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=30166&control=SetCommunity&CommunityID=225&PageID=30031#manualsResultPage
While they do not specifically address replacing the cable, you can find out how they do it when replacing the drive belt. As I said, it took me about an hour and I just about had to remove the transmission and rear drive assembly in order to unhook the original cable. Good luck!
Aug 14, 2009 | Toro Lawn Mower With Toro Power Tools
Gilmour 9400 water timer won't turn on
Well, I have the same problem. In fact, I just took mine apart (look for 4 screws on the back gray plastic) and found that the gears are stripped. About 3 of the teeth are broke off. I've been looking for parts on the Internet, but no luck yet. I'm afraid the only solution is to purchase a new timer.
Jul 11, 2009 | Garden
Dell 9400 Won't Start
i suggest that you should replace the battery because batterey may be faulty take it down to your nearest pc repair shop
Jan 21, 2008 | Dell Inspiron 9400 Notebook
Wont turn on
take the battery out and put it back in. try replacing the battery
Oct 10, 2007 | Samsung UpStage SPH-m620 Cellular Phone
LG VX9400 Cellular Phone Logo
56 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
