Question about Smeg 23 in. SE64 Gas Cooktop
One cook top is not working
One of my cook top, can ignite with full flame, but, the fire cannot stay on.
Even though I tried to press the knob for a long time, once my hand is off the knob, the fire distinguish.
  • 59 Answers
Even though you do not mention the brand and model of your Gas top, I am pretty sure that, that specific switch is bad.
With more info about the type and model I might be able to help you more.
Eddie Rentas
Tupper Lake NY
Posted on Jun 26, 2008
Gas burner will not stay lit. works fine when pressing knob for igniter function but goes out when knob is released
You have what we call a flame safe device fitted to the burner, (thermocouple lead), have you checked to make sure your flame on the burner is touching the tip of the "probe" on t'couple, if it isn't make sure that the ports on the burner are clear. If this does not solve problem then the thermocouple needs replacing by a Gas Safe engineer.
Oct 25, 2013 | Verona VEFSGG365SS 36" Gas Range with 5...
I have a Miele double burner combiset gas cook top and one burner ignites, can see flames but when leave the knob, it goes off. Flame doesn't stay on. What could be the problem? How can I fix it?
Need to use a small pointed object like a toothpick and stick in each small hole that flame comes out of on Brunner to clear jets.
Oct 13, 2013 | Cooktops
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
Spark igniters continue to spark:
let it all dry out
thumbs up
Aug 17, 2009 | Cooktops
When lighting one of the burners, the ingnition knob has to be held down over ten seconds for the flame to stay lit when the knob is released..
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 30, 2009 | Gaggenau 11 in. VG 232 Gas Cooktop
Gaggenau Cook-top VG 352-812 problems
Hi, interesting. I have the same units on my GasHob and my problems are exactly reverse. To turn the burners on it takes about 15 clicks and with some luck you'll get gas! Sorry, wished I could help.
Jun 08, 2008 | Cooktops
No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Mar 14, 2008 | Cooktops
Burner will not stay lit
Presuming the flame is touching the thermocouple, try putting slightly more pressure on the knob and hold for a few seconds longer. If this doesn't work try going through the same process with the knob removed - if this works you need to put a small piece of packing in the shaft of the knob ( a small piece paper might do). If this fails you need a new thermocouple.
Nov 10, 2007 | Miele 20 in. KM405 Gas Cooktop
Igniter will not turn off once burners are lit.
I've had the same problem for 2 years. Today I removed the four burner tops, the 15/16 inch bolt that holds the burners in place, took everything apart (simple connections underneath), completely cleaned and dried eveything. I also cleaned the 4 knobs and making sure the 4 swiches slide up and down freely then dried everything with a hairdryer. Is now works fine but if the problem comes back, I'll simply unplug the cooktop and light it manually. P.S. I stripped one of the large 5/16 inch bolt that had become weak and brittle. - Try using water or some liquid to loosen the bolts as necessary. Good luck, CHEERS!
Oct 13, 2007 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Smeg 23 in. SE64 Gas Cooktop Logo
277 people viewed this question
Top Smeg Cooktops Experts
ray gallant
marlin siecinski
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
