Question about Microsoft Xbox 360 Console
RE: Disc Tray won't open ~ help needed
Disc tray won't open when you push the open button on the console or the open tray button on the 360 dashboard. Any ideas? Thanks
  • dade4 Jun 23, 2008
    No comments
    Sergeant:
    Champion:
  • 427 Answers
The disk drive is broken, and will need to be repaired, if you have a game stuck in there, take off the faceplate and straiten out a paper clip. Poke it into the small hone under the cd drive until it manually opens.
Posted on Jun 23, 2008
416b-4174-b680-0f00-c000-0034
I had this error code as well. Here's the solution that ended up working for me:
  1. Eject the disc tray and remove any disc from the console.
  2. Important: Do not close the disc tray. Leave it open.
  3. With the disc tray open, remove the power cord from the back of the console.
  4. Gently push the disc tray about half-way back into the console.
  5. Plug the power cord back into the console.
  6. Push the power button on the console. The tray should close the rest of the way, then the console should restart and display the Xbox Dashboard.
  7. Important Do not use the controller or the disc eject button to turn on the console.
  8. Try updating your console software again.
What this does is put the DVD drive into Mode-B, which is an alternate operating state that allows the drive's physical memory banks to be flashed with new firmware. Because the latest XBL update involves flashing the drive with new firmware, you may need to physically put the drive in Mode-B. The latest update flashes the drive to make it compatible with Microsoft's new high-capacity disc format, XGD3, which will be used sometime in the future.
Jun 10, 2014 | Microsoft Xbox 360 Console
416B-4174-1601-0300-C800-0036
here's the solution that may work for you
My xbox says its connected to xbox live and it updates but when it gets to the end its say cant process update status code:3080-335a-1380-0500-cooo-0032
I think I had this error code as well. Here's the solution that ended up working for me:
If this solution was helpful, please leave a positive rating!
Jun 19, 2011 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
Hi,the door for putting disc in wont open.every time i push the button there is noise comn from machine like its trying to open but it cant?
This happens to me every now and then.
Here is how you can get around it:
Sometimes, you cannot open the disc tray on your Xbox 360 console by pressing the eject button. Any of the following things may cause this problem:
  • There is a hardware failure that affects the console, the disk drive, or the eject button.
  • A disc is lodged in the mechanism.
  • The clear protective plastic strip that is applied to the front of the tray to protect it during shipping is preventing the disc tray from opening.
To manually eject the disc from the disc tray, follow these steps:
  1. Unplug the power cord from your Xbox console. For more information about how to disconnect the power supply, click the following article number to view the article in the Microsoft Knowledge Base: 906205 (http://support.microsoft.com/kb/906205/ ) How to connect and disconnect your Xbox 360 power supply
  2. Position your Xbox 360 console horizontally, as you would position a VCR or a stereo component.
  3. Remove the faceplate from your Xbox console. For more information about how to remove the console faceplate, click the following article number to view the article in the Microsoft Knowledge Base: 907331 (http://support.microsoft.com/kb/907331/ ) How to attach or remove the faceplate on your Xbox 360 console
  4. Depending on the kind of disk drive that you have in your Xbox 360 console, you can use one of the following methods. Note In each case, make sure that you align the tool (a paper clip or stiff wire) to pass through another notch behind the hole on the console casing. Collapse this imageExpand this image906935.jpg
    • Method A: Insert a straightened paper clip or other small, stiff wire into the first hole from the left side of the disc tray. To release the disc tray, push the paper clip into the hole to press the manual eject mechanism. The manual eject mechanism is a white lever that is visible behind the console casing. The hole is located about 1.5 inches (approximately 4 centimeters) from the left edge of the disc tray.
    • Method B: Insert a straightened paper clip or other small, stiff wire into the second hole from the left side of the disc tray. Push the paper clip repeatedly into the hole to turn a gear to release the disc tray. The hole is located about 1.5 inches (approximately 4 centimeters) from the left edge of the disc tray.
    • Method C: Insert a straightened paper clip or other small, stiff wire into the hole that is directly under the "X3" logo on the Xbox 360 label on the disc tray to release the disc tray. The hole is located about 1 inch from the right edge of the disc tray.
  5. After you release the disc tray, the tray pops out slightly. You can pull the tray out the rest of the way to remove the disc. Note If you use method A or Method C in step 4, you may have to firmly press the disc eject mechanism to eject the disc tray.
  6. If you determine that a hardware failure has occurred that affects your Xbox console, contact Xbox Customer Support or submit a repair request for your Xbox 360 console.
(Information taken from: http://support.microsoft.com/kb/906935)
Hope it helped.
Nov 16, 2009 | Microsoft Xbox Console
The Disc Tray won't open!
press the button the it might go on if not take it back to the shop and say the disk tray wont open lol]
Jan 25, 2009 | Microsoft Xbox Console
Tray wont open
well, my bros does that as well. and i just push on the disc tray a little, like push it up if the console is laying down.. it also could mean the motor that pushes the disc tray is off or disfunctional.
Aug 04, 2008 | Microsoft Xbox 360 Console
Not reading any discs
My xbox is not reading discs. please help.
Jan 13, 2008 | Microsoft Xbox 360 Console
Disc tray
My console does the same thing just take the faceplate off and when you press the open button grab the disc tray and gently assist your console in pushing out the tray. Taking the faceplate off does not terminate your warranty.
Jan 12, 2008 | Microsoft Xbox 360 Console
Disc tray won't close!
i know this sounds carzy but mine just did that and i pushed it in hard but not too hard and then tried opened it and when i hit the close button it worked
Oct 27, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
99 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
