Question about Proscan PS60690 60" Rear Projection Television
ProScan 60 " Rear projection T.V..
Seems to have died suddenly.Power comes on for a few seconds and it goes off. No pictures at all.
I have a proscan ps60690,it will power up sometimes,sometimes it wont,there are 3 projector bulbs in it,2 will light the 3rd wont,also look inside of projector the filament look broken,tv repair man want 14o dollars just to come out and look at it,other repairs may occur,should i junk it. thanks bo
Posted on Oct 18, 2008
Power supply,safety protection has kicked in
Posted on Aug 24, 2008
My tv wount stay on it goes off after a few seconds
The tv "LAMP" LED light indication flashes or lighting up?The projection lamp has not been change in this tv like a 1 1/2 or 2 years?The projection lamp life is over.replaced the projection lamp.
Sep 17, 2010 | Proscan PS60690 60" Rear Projection...
Power but no picture or sound
Actually, it seems the the ballast might have got damaged. This seems more like a ballast issue, it's easy to fix, plus ballasts run around 60 dlls.
Aug 10, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Pictures goes black while power light blinks green
I have a 40 but i was having the same problem. It turned out to be my lamp. I got a brand new lamp from Projector Lamp Services (relampit.com) and my tv works fine now. Im pretty sure that the 40 and the 60 take the same lamp. You might want to give them a call.
Jan 05, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Proscan PS61700 Beeping no picture
I have a 60in Proscan Projection TV. My picture is out and the TV only beeps.
Brian Allen
Feb 03, 2008 | Proscan PS61700 60 in. Rear Projection...
Will not power up
I had the same problem and It called for a lamp replacement to the tune of approx $600.00. Of course the extended warranty does not cover lamps.
Feb 02, 2008 | Zenith D60WLCD 60" Rear Projection...
Hitachi 60" picture flashes on and off.
I've had the same issue although I don't unplug everything. I turn it off and then unplug it from the wall for 10 seconds then plug it back in. Seems ok after that. Has happened 4 or 5 times over the 10 years I've owned it.
Dec 20, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
60inch rear proscan picture hour glass problem
Most likly this set has two or maybe trhee problems .. first one sounds like a main power filter is open or the main power supply is at fault. the second coulkd be related or the cause of the first problem and could be shorted convergence ICs. the third could be a bad flyback transformer and good luck if thats the problem.. if the sets 10 years + in age, i would think very seriously into investing much to get this one going again.
Sep 11, 2006 | Proscan PS60690 60" Rear Projection...
Open Questions:
Proscan PS60690 1st turns off then on by itself. Then 3 on-off cy I've had this exact problem twice. The 1st time I replaced the RCA part number 205064, which I believe is called the HV splitter. I used a generic non RCA part. The TV worked great for several months but went out again and it has been broken for 2 years. I finally ordered the new true RCA part number 205064 HV splitter. The TV, again seemed to be fixed, and what I a beautiful picture it had through our cable box. But, no happy ending at this point. It worked for a couple of days and then turned off and back on while my wife was watching it a few minutyes ago. It cycled off then back on twice in a 3 minute period so with the picture showing and tv still on she went ahead and turned it off. This is how the problem began several years ago the 1st time it went out. I don't want to turn it back on anymore in case the brand new HV Splitter is still OK. Does anyone know what other parts may be going out, causing the HV splitters to go bad and start shorting out. I know the HV spitters have been an ongoing problem with these sets, but since I just put a brand new RCA one in only 2 days ago I'm wondering if something else goes out first and causes the splitter to go bad after a period of time. I would appreciate any help. I can't afford a new set right now and the picture looks so great on this set using a cable box I feel it's definately worth fixing. ps Could missing o-rings cause this? I've never seen the o-rings. Even the first time I replaced the HV Splitter. Thanks
Feb 28, 2017 | Proscan PS60690 60" Rear Projection...
Televison & Video Logo
285 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
