Question about HP Office Equipment & Supplies
My computer will not setup on my computer. printer is not located in list c 6280 all in one
  • 40 Answers
Lets start with the obvious question ? Do you have a disk that may have come with it ?
If not, then go to the support site ( I am assuming HP) and you can download the drivers for your printer there.
Posted on Jun 23, 2008
Where is the IP address located on my Lexmark s515 printer
Printing a network setup page
A network setup page lists the configuration settings of the printer, including the IP address and MAC address of the printer.
  1. Load plain paper.
  2. From the printer control panel, navigate to: button_home_0.jpg > Setup > button_select_0.jpg > Network Setup > button_select_0.jpg > Print Network Setup Page > button_select_0.jpg
Nov 30, 2013 | Lexmark Office Equipment & Supplies
HP 6280 Printer. Not printing. Ran diagnostics form HP software. No issues. Printer an computer are communicating. Can run alignment test and Diagnostic Print Page from computer without issue. ...
Well you definitely have a pc problem and not one of the printer. the printer just prints what it is sent and as you can print the alignment page that takes care of the printer.
You have reinstalled the driver but did you remove the old one first? I bet not. You should download the hp printer removal tool. Run it and after a restart then you can install the driver. Personally i would turn off the auto update feature as hp updates really mess things up.
I reckon after the reinstall the printer will be fine.
Jul 23, 2011 | HP Photosmart C6280 Printer
I LOST THE CD TO DOWNLOAD THE SOFTWARE INTO MY COMPUTER. HOW DO I DOWNLOAD THE SOFTWARE IN ORDER FOR ME TO USE THE PRINTER.
can u locate the download made?
if no then go to drive C and locate a folder called "downloads" it would be there.
if the download u made has a setup.exe hurry.double click it to lunch and follow the instruction to complete setup,make sure you select the option make printer default.
note some printer require u to cornet it to the computer before running setup.exe others do not but require it during the installation process. so read the instruction well.
But if the driver only unzips then you have unzip and follow this process.
go to printers and devices ,(with XP you will find it on the start menu, vista and win 7 it wold be in the control panel) .Click on add printer and follow the instructions.select the option that lets you install from a selected/advance location by you.depending on the OS you are using you have to browse for the advance location or click next for that step.to locate the unzipped driver,click the browse button and locate drive C the driver will be listed select the folder and click next to install the driver.
you can also get the driver at this location
http://www.downloadatoz.com/driver/articles/samsung-scx-4521f-laser-multifunction-machine-print-copy-fax-scan-driver-download-for-windows-98-me-2000-xp.html
Nov 25, 2010 | Samsung SCX 4521F All-In-One Laser Printer
When I put sd card in memory slot on hp 6280 all in one printer it sees the pics on the card but will not allow me to save them to computer. tells me not set up you need to install device software, wh
You need to save it manually. Locate on your My Computer where your SD card shows off, open the folder then copy watever files you want to copy from you SD memory card to your computer.
Hope this would help your problem :)
May 27, 2009 | Computers & Internet
Printer C6280
visit hp.com and download the driver mentioning the model no. of your printer and save it on your hard disk drive. then install from there
Jul 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Vista driver for HP 825C printer
What a great idea Marc! It worked!
"Hi, I just resolved the same problem. I installed from the VISTA preinstalllation list of printers the driver and files for the HP 830C/832C printer. The "install a new printer" on the control panel-printers page shows it on the list. After installation I went to the 830C/832C printer properties and selected it to be located in the USB virtual printer port where my 825C was connected (select any USB it does not matter). Now the VISTA believes that you have a 830C/832C printer on the USB and prints perfectly with this setup on the 825C.
Bye, Marc
Feb 16, 2008 | Microsoft Windows Vista Ultimate Edition
Can not clear the print que
Follow these steps to resolve the issue. Step one: Delete the print queue Open Print Setup Utility located in the Application/Utilities folder. Double-click your printer in the printer list to open the print queue. Click the Stop Jobs icon. Click to select the document, and then click the Delete icon. Repeat the steps for all the jobs in the print queue. When the print queue is empty, click the Start Jobs icon. A message appears: No Jobs Printing . This indicates that the queue is clear. When you have cleared the queue, retry your print job. If the procedure has not resolved the issue, repeat steps 3 and 4. If the issue still persists, continue to the next step. Step two: Remove the printer from the list Open Print Setup Utility , located in the Application/Utilities folder. Click to select the Photosmart icon. Click the red X to delete the printer from your system. Close all open windows, and restart your computer. Step three: Add the printer to the list Open Print Setup Utility located in the Application/Utilities folder. Click Add . Select the printer that you want to add, and click the Add button. After a few seconds, your printer appears in the printer list, and your printer is ready to print.
Sep 13, 2007 | HP PSC 1410v All-in-One Printer
Ben Johnson
