Frigidaire Washer Model FWT647GHSO
The washer is "marking" items being washed. I don't know if it is grease or dirt. I need to fix the issue before we ruin something important.
thanks for your help
Robin
  • Anonymous Aug 28, 2008
    I changed the boot on the door, I removed and cleaned the soap and softener dispenser, cleaned the drum and still the problem persisted and the unit is not even five years old. What a piece of junk frigidaire is. Need to buy a new one.
  • rmillers5 Nov 01, 2008
    I have the shaking problem and marking on the clothing.
    Did you fix yours? and how much did it cost for parts and what parts were replaced?
I had the same problem with my FWT647GHSO front loader shaking, the bearings in the outer rear drum were gone, I repair machinery for a living not appliances ( except my own ) and the job took me close to 4 hours to complete, it is working well now but I did notice some hairline cracking on the yoke that holds the inner basket so I guess it's time to start saving my pennies for a new one :( too bad the inner drum is ~$200.00 or I would endure the 4 hours labor again to replace that as well. Best of luck
Posted on Mar 24, 2009
The shaking we had as well. No dirt or anything, but it was the unit that controls the shaking that control the motor. about 150$ for the unit.
Posted on Sep 06, 2008
It's the greese from the bearings. The seal has broken and the machine is on a one way road to the junk yard. I have the exact same model and looking for a replacement at this time. It will start to shake/make VERY loud knocking. I've talked to numerous repairmen.
Posted on Jun 29, 2008
The dryer dispels sand and dirt after each cycle- I think it needs to be cleaned?
do you see marks on your clothing if not the problem may not be with the dryer but the washer. do you live in a sandy area? with kids check the pockets of item before washing generally not a very good chance of dirt or sand coming from the dryer
Aug 19, 2009 | Frigidaire Dryers
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
Dirt streaks appear after laundering
Grease seal for the bearings need to be replace. Unless you are a DIYer this is an expensive repair. Labor to install a new grease seal is about 400 to 500 dollars depending on the area. Parts will run about 100 to 150 dollars. The grease seal is cheap about a $10.00 part, but since ypou have the washer torn apart, and the grease seal has fail, you should also replace the bearings.
May 17, 2009 | Frigidaire FWTBB30DS Front Load Washer
Clothes are dirtier after washing...
The problem with your front load washer is a broken rear bearing. If you remove the rear panel, you will see brown "gunk" all over.
If you want to repair it on your own, order this:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-GLTF1240AS0-%3d%3di407639&PartID=407639
Good Luck!
Feb 01, 2009 | Frigidaire GLTF1240A Front Load Washer
go to your local appliance store and ask for "Affresh" washer cleaner. works excellent. If hubby need to get into the machine have hime clean out the pump. You probably have **** in there thats also contributing to the problem. good luck
Jan 26, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washing Machines Logo
954 people viewed this question
Top Washing Machines Experts
