Question about Durabrand DWT1905 TV
BH2004D Won't turn on. Outlet is OK. Is there a fuze?
  • Anonymous Jul 09, 2008
    want turn on
I opened the back found out that the circuit board slid out easily and at the bottom is a 2A 250V fuze which was burned out. A $2.50 replacement from Ace hardware fit in nicely and the TV works perfectly now.
Posted on Jun 23, 2008
Where do i find the fuze on a buick terazza for power outlet?
try checking the fuses and if it's ok then change the power outlet
Sep 11, 2014 | 2007 Buick Terraza CXL Wagon
Tv won't turn on
Have you checked whether the power outlet is ok? Have you tried connecting the TV to another power outlet? If so, there is a defect inside and should be handled only by a qualified service technician.
Aug 13, 2012 | Sony KDL-52W5100 TV
Siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
Apr 12, 2012 | Siemens Washing Machines
I had my bosch 1400 W 12 amp vacuum plugged in and it blew a fuze so I reset the home fuze box and went to plug it in and it sparked and blew the fuze right away. The plug was very hot to touch. I am...
Often if the plug or cord is a problem, it can be seen. Look carefully at the plug, are the prongs straight? Is the cord damaged where it enters the plug? Is the cord damaged where it enters the vacuum? If the plug was rotated, it is possible that the wires inside the cord may have frayed insulation and are making contact with each other.
If it is the plug or the plug end of the cord, you can get a new plug at Home Depot and replace your old one.
Also, if you have a switched outlet or switched multi outlet extension, you can shut the power to the outlets off, plug in the vacuum and turn on the switch so you are not near the plug when you plug it in to test it.
Jun 23, 2011 | Bosch 12-Amp Formula Canister Vacuum with...
It will not turn on,I checked all the plugs, an everything seemed ok.
ok heres what you do open your printer up there should be a fuze inside change the fuze but make sure you go by the same amps on the fuze.and if this fails make sure its pluged in all the way .
Jan 25, 2011 | Lexmark X3350 All-In-One InkJet Printer
Which fuse do i use for dodge power outlet?
it should tell you in your car manual under the fuzes and will tell you what color and what nuber it is the fuze box cover should have some spare fuzes
Mar 09, 2010 | 2005 Dodge Grand Caravan
Durabrand tv model#BH2004D need code for GE universal remote
The code for GE universal remote for th Durabrand BH2004D is "0157"
May 07, 2009 | Philips (PM625S) Remote Control
Sandisk Sansa will not charge
Use the USB/data cable (the same cable you used to transfer music to the Fuze). Plug the other end into a powered USB outlet or an AC adapter.
Apr 07, 2009 | SanDisk Sansa Fuze MP3 Player
Durabrand DWT1905 TV Logo
83 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
