Question about Video Cameras
Canon ES10V solution
You just responded to my question and I forgot to mention that the tape is still around the drum, will this still work without damaging the tape?
  • 3,037 Answers
I further responded to your question, please check it and let me know if you have any further questions with it, thanks
Posted on Jun 23, 2008
Camcorder is dead, need to get the tape out!
I would not recommend trying to remove a tape that is stuck Because the eject and load mechanism is controlled by a motor and you have to supply voltage to in the correct polarity to get the camcorder to take the tape in or eject it, that means that you would have to disassemble it.
That is the case with all camcorders - analog, digital, new or old. If you need the tape I suggest sending it in to a shop If you can do the repairs yourself
Dismental the camera. Try to locate the power board. have a look at the components near the battery connector or the power connector. there you will be able to locate 3 to 4 safety fuses. check the continuty. if found open replace it or jump them and and try to eject it.
you can also try to locate the motor for tape deck loading mechanism. Remove the flex ribbion connector of the motor from the pcb, then try giving 3 volt supply from an external device to the motor in both the direction. in one direction it will move the deck outward, but be carefull when the cassette is being ejected a little portion of the tape may get damaged.
Jun 22, 2008 | Canon ES10V Camcorder
I have the same jittery picture on playback on a Sony DCR-TRV460. I see you've stated that the drum could be misaligned/damaged. I've used the cleaning head with no success. I need to keep this device...
Yes sometimes when realigning the drum will not work. if the tapes were recorded with the drum out of alignment all tapes would have been recorded out of alignment. Delt with that situation where my player wouldnt play a customers tapes because his drum was out of alignment from factory. I had to use his camera to play all the tapes that were recorded on his camera.
Mar 23, 2011 | Cameras
How to repair opc drum on canon ir400 without change it
if there is minor scratch on the drum surface, cover it with solvent based glass colour let it dry and re install the drum. if there is scratch on the sides of the drum full circle then cover it with selophane adhesive tape, make sure to wind the tape in counterclockwise and one turn only.
Oct 06, 2010 | Canon Office Equipment & Supplies
Canon XL1. Unable to playback tape in camcorder
I have the solution that the canon expert forgot to mention. And this solved my exact problem too. I put in the tape and then shut the white door over top. This doesn't engage the tape. Problem solved. Human error, The fix cost nothing.
Mar 04, 2009 | Canon XL1S Mini DV Digital Camcorder
Drum error : slide the green tab on drum unit in each colour?
you forgot to slide the tab, unless you do this you cannot use your printer im afraid, drum unit is a cylindrical part unit, unless otherewise you correct this instlltion procedure there is no othere way around it
Nov 25, 2008 | Brother HL-4050CDN Printer
Video camera classes
Check with your local community college
Aug 03, 2017 | Canon ES10V Camcorder
Camcorder is DEAD, need to get the tape out!
most cameras of this type have a series of cogs inside that u can manualy turn by hand or by using a small screw driver,wich will inturn open casset mechanism you need to have a good look and you will suss it out i have done this many times with camcorders dvd players and vcrs, take care andy hope this helps
Canon mv700 not loading tape
if you hear the cylinder drum running to fast try take out the connection of the drum at the circuit and back it again...try this in you can open your camera....
Aug 08, 2007 | Canon MV700 Mini DV Digital Camcorder
Lcd viewer
Probably the ribbon cable that connects the LCD to the camcorder is cracked or getting pinched somehow.
Jan 27, 2007 | Canon ES10V Camcorder
Video Cameras Logo
32 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
