Question about Clarion Wired Marine Remote Control
JVC Marine radio on 2002 Malibu Boat
I have just purchased a 2002 Malibu Boat. It has no radio, but 2 JVC wired remotes one on dash and one in rear. looking at the wiring it has what looks like a 6 pin white plug that connects the 2 remotes and a 6 pin plug that looks like it goes to the radio any ideas? Also will I have to purchase a JVC radio to work with these remotes as well or can I purchase another brand?
Thanks
Ron
  • sdhughes398 Jul 04, 2008
    I am in need of one of those remotes so if you ever want to sell one let me know.
  • Dale Nelson Dec 27, 2011
    If it is like my Clarion the 2 remotes connect to a Y connector which go to a single 6 pin connector that comes out of the radio. Both will opperate the radio.
IT may be to late but you can buy a JVC radio model KD-SX50M tat will be plug and play. I just purchased one for 69.00. I had a simialr situation and that was all it was.
Posted on Jun 30, 2009
Will a Midland 75--810 communicate with a marine band radio?
Sorry Paula
The 75-810 is an CB radio that DOES have Wx capability but it won't communicate with marine band VHF's.
Hoe this helps you out.
-Steve
Oct 31, 2015 | Boating
I have a Clarion Marine XMD3 radio in my boat. There is a set of speakers in the back of the boat and a set in the cabin below deck. The set in the below deck cabin work fine. The set in the back of the...
Look for loose or broken wiring connections. Swap front and rear speakers wires at radio and determine if problem is the radio or the speaker system.
Aug 01, 2013 | Car Audio & Video
With engine running on boat, radio transmitts with
This is almost always caused by a poor ground. I would suggest you run your ground wire (larger the better) back right to the negative terminal of the battery.
Hope this is helpful.
Jul 14, 2010 | Uniden Solara DSC VHF Marine Radio
I have a clarion marine remote installed on my boat. The display works but the buttons do not. Is there a fuse for this remote
Mine just did the exact same thing this weekend. Have you had any luck finding a solution. I've checked all the wiring and no fuses that i can find.
Jun 06, 2010 | Clarion Wired Marine Remote Control
2002 Malibu: where do I fine the fuse for the radio in a 2002 M...
YOU HAVE FUSES PANELS ON BOTH SIDES OF THE DASH.THE RADIO FUSE WILL BE 10 AMP FUSE.
May 16, 2010 | 2002 Chevrolet Malibu
I just purchased a uniden solara dsc.I HOOKED IT UP AND THE NOAA WORKS BUT I TRIED TALKING AND NOTHING HAPPENED.(I have a tractor with a radio and neither of us could hear each other).
The Uniden Solara is a MARINE RADIO not a CB. Marine (boat) radios operate in the VHF-Hi range and CB is in the VHF-Lo range. You also need a license to operate a marine radio, or you can identify yourself with the name of your boat but you MUST be in the water.
Jun 20, 2009 | Uniden OCEANUS-DSC-BK Base CB Radio
Radio works on tech bench, not in the boat
Yes, the yellow wire is the switched hot lead - it is typically connected in one way or another to the ignition switch. There is also a smaller gauge red wire that is connected directly to the battery (through a fuse of course). Both of these wires have to have power for the radio to work. Also the black wire has to be connected to a good ground. If all three of these wires are confirmed to be in good order (power where there should be power, ground where there should be ground and no shorts) the radio should at least power up when they are all hooked up and the ignition is on.
Jun 16, 2009 | Clarion Boating
2 way radios
Your radio with model number M33GMC09C2AA is a GM300 made for Central Asia, Eastern Europe and Turkey. It is VHF 25 watt with 12.5 channel spacing. It will do frequencies between 146-174 MHz. It should be able to be "read out" by a Motorola dealer. If it has been in a boat, it most likely is programmed with Marine frequencies. If you have another marine radio you may be able to determine the frequency by process of elimination.
The wiring kit for power is readily available for around $18 ea. If your boat has a marine VHF antenna onboard, you will be able to attach the antenna to this radio. It takes a mini-PL connector.
Sep 14, 2008 | Motorola Radio Communications
Just bought a secondhand Kenwood KDC-3024 for my boat
White and white Stripe = Front Left
Gray And Gray Stripe = Front Right
Purple and Purple Stripe = Right Rear
Green and Green Stripe = Left Rear
Feb 18, 2008 | Kenwood KDC-3024 CD Player
Clarion Wired Marine Remote Control Logo
1,075 people viewed this question
Top Clarion Televison & Video Experts
Tom Chichester
Are you a Clarion Televison and Video Expert? Answer questions, earn points and help others
