Question about SanDisk 4GB Memory Stick PRO Duo Memory Card
When i try to format the memory card, it displays that the memory card is locked. How do i unlock it?
  • 17,130 Answers
There is a tiny slide switch on the side of the memory card if you look on carefully. Slide it accordingly as indicated to unlock, this is provided to prevent accidental erasure of important data in the card.
Posted on Nov 24, 2010
SOURCE:
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
HOW TO UNLOCK 2GB MICROSD MEMORY CARD?
Are you using an adapter for the memory card?
The adapter will have a lock in the indicated place. Use it to unlock.
If you are not using an adapter, you might have used some software to lock it. If you don't remember, you may have to format it first. But by formatting, you will loose everything in the memory card!
Jul 19, 2011 | SanDisk 2GB microSD Memory Card
My phone memory card is not format and not data deleted
try to see your memory is locked or unlocked.. there will be a switch to lock or unlock. if the memory in locked condition, try to switch to unlocked. maybe that was the problem. hope this useful. regard, riyan
Feb 26, 2011 | SanDisk 2GB microSD Memory Card
I am newbie, I can not format my flashdisk as it is locked though I never locked it before. Many thanks
Hi Thanks for your question.
Thank You for using FixYa.
Jan 17, 2011 | Electronics - Others
Memory card locked
Jan 16, 2011 | Canon PowerShot A520 Digital Camera
Memory card is write protected
you can see a tiny lock (kind of sliding button with the label ("lock") in memory card. Try it
-Saran
May 06, 2008 | Motorola Mobility ROKR E6 Smartphone
E6 - memory card locked
remove the memory card from the phone and look for manual lock on MMC adepter and unlock if it is locked.
Feb 14, 2008 | Motorola Mobility ROKR E6 Smartphone
SanDisk 4GB Memory Stick PRO Duo Memory Card Logo
166 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
