Hi, I have recently bought a JVC Everio GZHD7AA camera to continue filming wildlife and editing with my Adobe system which has worked so well for years. I had huge problems with the computer not accepting the TOD files but with Cyberlink Power Director and Power Producer i can now get these clips on the timeline in both and cut to DVD. I cannot get them to run on Adobe Premier 6 which is by far a better place to edit, cannot even bring them back off dvd. Could you please give me some suggestions on which way to go. Thank you Clark Australia
  • clarkmcghie Jun 23, 2008
    Thank you Worldvet,
    Still no deal. When I try and change the file name it goes unstable.
    Here are the steps I have been taking.
    I had a professional download my files from the Everio HD7 camera onto DVD as AVI files as suggested to me.
    Start Adobe Prem6, click on import, go to file, go to my computer, disc drive, select, comes up Audio TS and Video TS, will not accept down to "File Name" window to be imported.
    On Adobe P6, import, backup, TOD files, select file folder, select, no scenes come up in main window under All File Formats. Go backwards, select folder again, open, files displayed as TOD, click play and they play with VLC media player but like 4 frames per second.
    I contacted JVC and was less than happy with their approach overall. Was told finally after much debate over problem to reinstall camera disc. I did this 3 times and finally Power Producer and Power Director would accept TOD files. At this stage I though we were on a roll.
    I select Cyberlink Power Director Express, select same file, highlight, it accepts into File Name, accepts through to timeline, can then build files into a clip, go to produce, create a file, then to step 2, select MPEG2, to step 3, produce a movie, this puts a MPEG2 file onto my hard drive. From here, I go to Power Producer, bring in the file, burn it to a DVD which plays well in all computers and TV sets.
    I now try to open Adobe P6 to do my editing, add stored files for logos etc. Power Director is so basic to try anything with. I select DV Pal Widescreen, ok, Import, File, Select project (ie; Produce 4a.mpg) it opens in File Name window, All Format types, Open and there it is in Bin as Item 1. Grab the file and drag across to second monitor window as usual but it will only play at about 2 frames/sec and no audio (line is flat and red) Quality looks good but cannot edit.
    Awaiting your reply and thanks,
    Clark
    Thank you Proton77,
    There is no error report shown on Adobe when I try and edit.
    The problem seems to be trying to get the mpg files to run on Adobe 6. They play, record etc well from Power Producer.
    If Power Director had even a fraction of the features Adobe has to edit with I would be going okay. At present, I am working 20 hrs per day (doing work that should take 2 hours) getting footage ready for a major section of my business and this problem is crippling me.
    Any extra help or suggestions will be appreciated.
    Clark
    Guru:
  • 859 Answers
This is JVC's proprietary extension for MPG. Just rename the file from *.mod to *.mpg and then work with it. You shouldn't have the probelm. You could also look for a patch to premier that adds the tod extension but renaming it is easier for now.
Regards,
Worldvet
Posted on Jun 23, 2008
  • Glenn Rogers
    Glenn Rogers Jun 23, 2008
    Clark, Are you able to analyze your base video files after getting them onto your hard drive a mpeg2s and examine the frame rate?
    We get customer's from all over the globe so I don't know if your in a PAL or NTSC country.
    What are the details on your meg2 file then, frame rate, bit rate, display aspect, High Def and if so which h type is that?
    There are some open source programs from sourceforge.net that are good at analysis, but I bet you already have Sherlock, etc from the K-lite pack or do you?
    My principal conclusion initially and most likely your hunch as well is that the import filter for Premier is what is weak or the
    Regards,
    Worldvet
  • Glenn Rogers
    I don't wonder if your camera is recording over to NTSC 23.97 fpm and your instructing premier to work with PAL and this may be where the adobe filter is failing you.
    You may want to get a couple of apps from SourceForge.net
    Hand Brake which was designed for the Mac and has been ported to Windows.
    And, Media Coder which I use to do file conversions most of the time. It is the most versatile program out there that's free for doing straight conversions of mpeg2 to mpeg2 but a different bit rate which may the entire problem with Premiere. A really high bit rate will slow down any player or software, where in your studio master you may be just fine with a 1500 or 2500 bit rate sampling. Media Coder will analyze your file first once you get used to finding the information from the controls. If you get settings out of sorts you can reset defaults from the File Menu and start over. The forum for Media Coder is a great resource too.
  • 1,183 Answers
Give me a min
  • 1 more comment
  • Mandeep  Singh
    Mandeep Singh Jun 23, 2008
    To help you better i would require some additional info...
    IS there an error message displayed on the Adobe Premier , when you try to play the file.
    Thanks
    proton
  • Mandeep  Singh
    I was able to find closest possible solution to your problem on the following link. The problem is TOD extension would not run on adobe . You need to convert the same to mpeg to un and edit
    check the following link
    http://www.adobeforums.com/webx/.3c03461...
  • Mandeep  Singh
    As you are already using the Power director, you can convert the TOD files to mpeg video and use the same in adobe to edit.
    If you intend to export .TOD files to another application such as Adobe Premiere then it will be easier to track the locations of the Cyberlink output. Download video files from the camera via USB to the designated storage area. Rename files as required. Default names can cause problems later.
    1.Open Cyberlink PowerDirector Express 5 NE. Set up the file locations in preferences.
    2.Notice that the designated EXPORT folder is empty
    3.Import .TOD files into PowerDirector Express
    4.A conversion takes place automatically during the import process.
    Thanks
    Proton
    Ps. I'll try to find the images for you for the above procedure, so that its more helpful to you
Need an owners manual,user guide, or instruction manual.
Please find all help by clicking on the model you have from the link below:
JVC Everio
Feb 17, 2011 | JVC Everio GZ-MG21 Camcorder
Looking for a jvc everio gz-mg155u manual
You can download and print the instruction manual for JVC Everio gz-mg155u in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Nov 01, 2010 | JVC Everio GZ-MG155 Camcorder
Hi could you please send me a manual for a jvc everio gz-mg630 thanks liz
You can download and print the instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Oct 07, 2010 | JVC Everio GZ-MG630 Hard Drive Camcorder
Software to edit MPEG2 format film
try the software that came with the camera if not then go to Everio and see if they hae some patches to download good luck
Sep 21, 2009 | JVC Everio GZ-MG360 HDD Camcorder
Lost the disks that came with hybrid everio(JVC) 30gb
You can go to the cybelink website and download a trial copy of the software that came with the camcorder. The software is ; Cyberlink Power Cinema, Power Directer, and Power Producer. The camcorder's format is also recognizable by Mac. Or if you dont want ot eventually buy the new software you can manually change the file extension of you movies off the camcorder to .mpg to view back your video using windows media player. Until you get editing software, you would not be able to edit your movies. Adobe Premier Elements 4 works fine with .mov files and Final cut pro.
Dec 29, 2008 | JVC Everio GZ-MG130 Camcorder
Hard disk error
I need to buy only the Dock of JVC Everio HDD Video camera Model- (GZ-MG135AA).I bought it recently but lost only the dock.If you can supply that please let me know with the cost and the delivery method.Regards,
B. Wijesinghe
Email - dhammikawj@yahoo.com
Tel (03)94340379
Mob 0437103913
Apr 22, 2008 | JVC Everio GZ-MG130 Camcorder
JVC Everio GZ-MG145 backup on mac - files are .mod
The software iVerio might help you. It transfers and converts automatically all your videos from your HDD camcorder.
Have a look on the site http://www.convertmod.com
Feb 21, 2008 | JVC Everio G Camcorder
Changing shooting size to 320x240 on jvc everio hard disk drive
The everio series uses image quality setting for resolution. The lowest setting is economy so try it in that setting. If the images is still to large then this means the everio can't shoot any lower so you would have to edit it. A quicker solution I think for You tube posting is get a low end camcorder the the flip or one that shoots the video on a media card. These are lower resolution cameras and run around a hundred.
Feb 07, 2008 | JVC Everio 25x/20GB Hard Disk Drive...
JVC Everio GZ-MG21 possible broken lense ?!?!?1
Do you have all the manuals
JVC manual site
Download2.gif and install adobe reader2.gif, if needed
Right mouse2.gif click and "save target as" to save each manual to a file
Dec 09, 2007 | JVC Everio GZ-MG21 Camcorder
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
