Question about Saeco Incanto Classic Espresso Machine
Coffee too weak
I just bought a Saeco Incanto, but after adjusting the coffee dose adjustment and SBS find that it is still far too weak to drink.
Any ideas on how I can make a strong coffee?
  • costavar Jan 23, 2009
    Mine too, with time it became stronger. Now i just serviced the machine and its back to weak coffe. Its a basic saeco incanto model. Coffee grind setting 10, coffe amount 2 dots past the middle of the knob,
    I tried reducing the amount of water thinking that the coffee will be more dense but no difference.
  • 515 Answers
What kind of saeco incanto do you have?
Posted on Jul 10, 2008
Coffee is too strong. How to dose Saeco Incanto classic? i tried to adjust SBS and beans regulator but coffee is strong and big coffee fills only quarter of cup.
press and hold the big coffee button while coffee is making,when you thing that amount is enough ,take of yuor finger ,Thats it. Next time just press the big coffee button once .
Sep 29, 2013 | Saeco Incanto Classic Espresso Machine
How to change brew group rubber orange gasket on saeco Incanto Sirius
google for USA-Incanto Rondo SBS-RS, E74088 Rev. 03.pdf
it has an exploded view of the brew unit. partsguru has the part.
Jan 30, 2013 | Saeco Vienna SuperAutomatica Coffee...
Make coffee stronger on a saeco machine
Hi, adjust coffee amount knob more towards +, which will grind more coffee for brewing. The knob is the smaller one inside the bean hopper.If the machine has digital display(Incanto Deluxe) it can be set in the menu.
Jul 29, 2010 | Saeco Incanto Coffee Maker
My Saeco Incanto Sirius grinds the beans but does not pump out the coffee into the cup
If you already tried the previous suggestion (grind at the most coarse setting) and you still get no water, it may be the SBS brew valve.
As a test, run a blank shot by telling the machine you are going to add preground coffee but don't add any coffee. When you start your shot you should get plain water (probably tea colored as it flushes out some old coffee left behind from previous brews).
If you still get no water, then it is either your brew filter screen is plugged or the SBS brew valve is plugged.
Remove the filter screen and hold it to the light, can you see through all or most of the tiny holes? If not, soak it in a good coffee detergent and scrub it with a toothbrush until the holes are clean (DO NOT USE A NEEDLE TO CLEAN THE HOLES).
If it is the SBS brew valve, you can open it fairly easily to clean it but there are a couple of tiny parts and a spring so be careful.
And final thoughts - the SBS brew valve can be defective - I've had some that were too tight and simply wouldn't allow any water to flow at all. But since yours was working before, it probably just needs cleaning.
Jun 12, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
Grounds dry, non-pressed and jettisoned to bin. Pre-ground function fine. Otherwise, no coffe.
The solution to this Saeco Incanto Deluxe problem was simply tweaking the Program Menu settings. After receipt of the unit, I immediately set all settings to STRONG. This move proved to be a major complication because the machine could not compress the load of grounds being dumped into the brew unit. I responded by setting ALL coffee settings in the Program Menu to MILD and now only use the Large Coffee SBS setting for regular coffee (the coffee is still robust and delicious).. The expresso SBS setting and those SBS settings further to the left I use only with the small cup button. If I want a double I just do it twice. The machine was protecting the drive shaft and brew unit from damage by stopping the press and jettisoning the grounds when I had the machine programmed the other way. I hope this helps other owners.
Jan 03, 2010 | Saeco INCANTO DELUXE Espresso Machine
Need to adjust coffee dose for odea go
SEE THE VIODEO AND OTHER LINKS ON TYHAT SAME PAGE:
ALSO:
Saeco Odea Go adjusting coffee dose Questions
May 21, 2017 | Saeco Odea Go
Coffee is too weak/light
I think I have the right manual. Page 29?
http://products.saeco.com/articolo.asp?id_linea=1&id_articolo=740823049
Jan 01, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Incanto
how tight is the coffee packed in the dripper, the flow rate is determine by how tight the coffee is, thats why you always see the barista press the coffee against the disk of the grinder dispenser in a coffee store
Jul 06, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
938 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
