Question about Thermador Kitchen Ranges
Stove and oven will not turn on. No digital display also.
  • 6,487 Answers
First and foremost do check all the connections.
Chances are the orifice is plugged up, if the valve rotates and no gas comes out of the burner. There are occassions when a burner valve will rotate and not allow gas to flow. In such cases, the valve is defective and must be replaced.
Since there is a remote possibility the burner tube is restricted or plugged, which would than allow gas to flow under to lid, I do not suggest match testing the burner to check for burner flames. Which is a test techs can use once they are sure it is safe to do so However, should gas be flowing under the lid and not be known, using a match to check for burner flames can cause major problems use caution.
The burners orifice is located on the top burners gas valve. The lid would have to be raised to access the gas burner valve. Than the burner removed. Than remove the orifice. Once that is removed it can be held up to a light. There will be a small hole in the orifice, which may be restricted or plugged. A pin can be used to clear it, if need be.
Also check the burner tube and be sure it is clear and all the burner ports. Ports are the holes in the burner. May have ignitor ports up a side of the burner head if the spark ignitor is not located directly to the side if the burner head.
Hope that helps........
Posted on Jun 23, 2008
  • 3,037 Answers
Most of the Thermador ovens have a thermal cut-off on the back of the oven or on the top (behind the control panel) and usually they are resettable.
Most likely your touch pad went bad and will need to be replaced if the reset above doesn't work. Let me know how this goes and whether you need any further help.
  • Benjamin Patri
    Benjamin Patri Jun 28, 2008
    If you are satisfied with your experience here, then feel
    free to provide me with some feedback by rating my solution. If you need any
    more help, I would be glad to assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • 426 Answers
Check all fuses, the power cord, the circut breaker and if you have a multimeter see if you have voltage at the plug in the wall
  • Lee N.
    Lee N. Jun 23, 2008
    see if there are any resettable fuses.. if the oven wont come on at all and there is power to the unit i would call someone to look at it unless you fell you have the experience to fix it
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Stove top works , oven does not
If the ignitor is not glowing to lite the oven then it needs to be replaced. Here is that part to order.
Whirlpool 74007498 Oven Ignitor AppliancePartsPros com
Mar 20, 2014 | Maytag MGR4452BDW / MGR4452BDQ /...
Oven won't work - digital display/control stopped working
probably a bad control board chekc out www.appliancepartssolutions.com
cheep parts...good luck
Jan 17, 2010 | Kitchen Ranges
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
yes replace the ignitor, this is the most common failures of ovens not coming on.
Dec 10, 2007 | Whirlpool SB160PEE Gas Single Oven
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Kitchen Ranges Logo
238 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
