Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
Missing file or corrupt
When i turn the labtop i get a message that says; windows could not start because the following file is missing or corrupt:
\system32\hal.dll.
please re-install a copy of the above file.
i dont have disc that camewith the labtop cd-rom disc
  • Anonymous Aug 24, 2008
    i have same exact problem, i need help
  • Hamish11 Sep 30, 2008
    Mine does exactly the same thing..
  • 39 Answers
Method 1 loadTOCNode(2, 'resolution'); Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP missing file or corrupt - uparrow.gifBack to the top Method 2 loadTOCNode(2, 'resolution'); Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  1. Use the Windows XP CD-ROM to start your computer.
  2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  3. Select the Windows installation that you want, and then type the administrator password when prompted.
  4. Type bootcfg /rebuild, and then press ENTER.
  5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP uparrow.gifBack to the top Method 3 loadTOCNode(2, 'resolution');
  1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  2. After the setup files are finished loading press R to repair using Recovery Console.
  3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  4. Login to the Administrator account by typing the password for this account, and then press ENTER.
  5. At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exeFor Multi-Processor systems: expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  6. If you receive a prompt to overwrite the file, press Y.
  7. Type exit, and press ENTER at the command prompt.
uparrow.gifBack to the top Method 4 loadTOCNode(2, 'resolution'); Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Note You do not have to include the /p switch in the Chkdsk command-line because the /r switch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch..
Posted on Apr 13, 2009
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
Tip
NTOSKRNL.EXE is missing or corrupt.
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution: Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
on Dec 27, 2009 | Computers & Internet
I HAVE A GATEWAY DESKTOP COMPUTER WITH AN ERROR MESSAGE SYSTEM32\NTOSKRNL.EXE. HOW DO I FIX THIS PROBLEM?
NTOSKRNL.EXE is missing or corrupt. Issue NTOSKRNL.EXE is missing or corrupt.
Related errors
Cause
  1. Keyboard issue
Solution
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you load the last known good configuration.
OS Loader v4.01
Check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you reinstall Windows.
http://www.computerhope.com/issues/ch000646.htm
Mar 02, 2012 | Gateway GT5026E PC Desktop
Following files missing or corrupt: \windows\system32\config\system
Well this means one of important files needed to start Windows is corrupted (it's a registry file).
I'd recommend repairing Windows installation. If you have Windows XP and also the Original Windows CD follow: this guide.
Dec 31, 2011 | Dell OptiPlex 740 (BPCW6TT) PC Desktop
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Ntoskrnl.exe is missing or corrupt solution
Issue:NTOSKRNL.EXE is missing or corrupt.
Related errors:
Cause:
  1. Keyboard issue
Solution:Keyboard issue
OS Loader v4.01
Oct 01, 2009 | Microsoft Windows XP Professional
Error: windows root>\system32\ntoskrnl.exe
Related errors:
Cause:
  1. Keyboard issue
Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 18, 2008 | Computers & Internet
How do I...
Related errors:
Cause:
Keyboard issue
Solution:
Keyboard issue
OS Loader v4.01
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
Computers & Internet Logo
173 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
