Question about D-Link AirPlus DI-524 Wireless Router
90% speed degradation
The speed degradation with the wireless is not 10%, it is 90%! (from 7.83Mbps to 0.73Mbps). In the mean time I understand that this may have to do with the wireless router supporting 11G protocol whilst my laptop side is 11B?
You mentioned dwitching off QOS packet formatting on the router side (the format that prevents freeloaders on my wireless), but I don't know:
a) how to do that
b) what the security consequences are
Can you help?
Thx
    Sergeant:
  • 320 Answers
The G vs B will play a huge role in speed.
To turn off the QOS feature usually consists of logging into your router or opening the management software that came with the router.
After looking up more information for your brand, I would check your d-link utility and possibly try switching channels (If your using 6 goto 11) try to at least move 5 channels from where it is already set. Also make sure power mode is set to "Continuous access mode"
Since your using a b card with a g router, my next suggestion would be if at all possible try connecting to your router with a g card (Possibly a friend or neighbor could help out) and compare the speeds. I am more then certain you'll see the speed you are wanting with the g card.
Posted on Jul 07, 2008
Can I configure my d-link DESS 1008D speed in to 10mbps manualy?
the 10/100 Mbps feature in the switch means it will auto-negotiate the speed with the other end, so in order to make it run at 10 Mbps, degrade the computer's speed to 10 Mbps and the switch will automatically follow. You cannot set it on the switch directly since its not a managed one.
good luck
Jul 13, 2011 | D-Link DES-1008D 8-Port Ethernet Switch...
I have a 20 mbps adsl line, but whene i connect the 3com 3crwe554g72 router wireless i only get 2 mbps , why?
This issue is most likely due to the quality of the signal between the PC and the wireless. If there is a lot of interference or the wireless devices are far from the 3COM, then the signal will be less then optimal. Sinnal quality will degrade quickly when going through walls floors and celings as the density and metal contained in these structures block wireless signals. Interference can come form other wireless devices, cordless phones, RC toys and some wireless mice and keyboards.
The other factor to consider is the type of wireless being used. Wireless like all technology get better as time goes by. As new technology comes out it is categorized and classified. For Wifi there are currently 5 separate specifications for wireless. They are:
802.11 (Specless) - approx 1997 era devices. operates at 1 to 2 Mbps
802.11 a - approx 1999. operates at 6Mbps.
802.11 b - approx 1999. operates at 11 Mbps.
802.11 g - approx 2003. operates at 54 Mbps
802.11 n - October 2009. operates at 100+ Mbps
If you have an old wireless device it will work with the 3COM but only at the speed it was designed for.
You can always check your speed by connecting directly to the 3COM with ethernet cable and going to http://www.speakeasy.net/speedtest/
Feb 05, 2010 | 3Com OfficeConnect Wireless Cable/DSL...
Two clocks are set at 6am one clock gains 30 seconds every hour and the second clock loses 1 minute every hour. at what time will the faster clock be 30 minutes ahead of the second clock
Compute the difference in clock-speeds, namely 90 seconds per hour.
Convert the units of time: 30 minutes becomes 180 seconds.
So, divide 180 by 90 to get '2', namely 2 hours after the 6 o'clock "start" time, which makes it 8 PM.
P.S. There is at least one error in the above solution. If you truly understand the solution, make the necessary correction, and submit the corrected "homework" to your teacher.
Jan 07, 2010 | M2K Garfield: It's All About Math Math...
Wireless problem
maximum cord length is 90 feet otherwise there is a resisitance factor that will lose its signal as you described
Aug 31, 2009 | Computers & Internet
Intermitent internet speed on medion laptop with Atheros AR5007UG wireless network adaptor
Hello, Peter_Street
What do you mean by intermittent Internet speed? Are you hardwired or wireless?
There are time when Internet traffic is heavy, does this happen at certain times of the day?
Aug 11, 2009 | Computers & Internet
Low connection speed
I understand that you are getting low wireless speed through the adapter. I would suggest you to upgrade the drivers for the adapter. If the issue persists, then please change the channel on the wireless router.
Hope this helps.
Regards
Anand
Jun 18, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
Apr 13, 2009 | Zebra Z6M Plus Thermal Barcode Label...
Want to FAX with My MagicJack(VOIP) using a standard FAX machine
holy ****, just google 'magic jack fax' and you'll get all the info you need. digital, analog, who cares, just do it.
Jan 01, 2009 | Computers & Internet
Speed degardation
Routers, firewalls, and other network equipment usually cause a 10% overhead degrade in service. You may also want to check to see if the router has any QOS/Packet Shaping features for the wireless side, If so turn them off. Some routers do this to prevent un-wanted wireless intruders from hogging bandwidth.
Jun 17, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
80 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
