Question about E-Machines eMachines Desktop PC
Keyboard locked i have the same problem with my keyboard i can't type, i read your solution and i no longer have the software, what can i do concerning this problem
  • 1,011 Answers
If you have usb keyboard then remove ur keyboard and restart windows. when it goes on then insert the connector. it will detect that one and may be it start working. or go in properties of computer--->device manager--->usb composite device and uninstall it from the top bar and then install it. it will detect all usb devices including keyboard.
Posted on Jul 23, 2008
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Scroll lock on mousepad get locked
    Try: To toggle your scroll lock key:
    1. Click on the Windows Start button.
    2. Select Run.
    3. Type 'OSK' in the dialog box.
    4. Click on OK.
    5. The Microsoft on-screen keyboard will open. Notice that the slk, or scroll lock, key (located in the top row of the on-screen keyboard as shown below) is turned on.
    6. Click on slk (in the top row of the on-screen keyboard). This will toggle the state of the scroll lock key. Notice that the scroll lock key is no longer outlined in red. Scroll lock is now off.
    Aug 29, 2012 | Lenovo INC 102495U Z570 Ip Ci321 156...
    I cant type anything it is can i unlock it..? though it does not require any product key?
    Be sure you have installed the product properly along with the product key. Read the manual for how to install before installing. And if then also the problem prevails check the keyboard connections and reconnect the keyboard with CPU and restart your system.
    Sep 19, 2010 | Microsoft Office Professional 2007 Full...
    Hi There. Not sure what key i've gone and pressed. The majority of the letters/numbers on my keyboard all work in first hand english but some of the keys where i have an option with a smaller blue number...
    You have turned on the numeric keys on your laptop. It is turned off/on by the following.
    Press the Num Lock key. If nothing happens, try Shift+Num Lock.
    If the text Num Lock is shown in a different color, find the matching-color key, such as Alt or Fn. Then press that key in combination with Num Lock.
    You’re successful when the Num Lock light comes on. At that point, the keyboard has switched into numeric keypad mode.
    Read more:
    Aug 04, 2010 | Computers & Internet
    Is there no indicator to inform you when the caps lock is on
    The LED's for caps lock, num lock, and scroll lock are located on the base/ reciever unit. Logitech did this to make your keyboard batteries last longer.
    Dec 17, 2008 | Logitech Cordless Desktop MX 3000...
    Toshiba Laptop Keyboard problem
    My Toshiba Satellite A45 S120 keyboard has a problem, some of the keys are not working. When you type it does noting. Sometimes when you start the computer, it continuously types the letter eeeeeeee. You can hit some keys randomly and this will stop, but if you start a program (eg. ms word) the same thing happens.
    Sep 05, 2008 | Toshiba Satellite A85-S107 Notebook
    If you have another computer in your home unplug the keyboard and try the locked keyboard on that computer, then vice versa plug the other keyboard in that pc and see if another KB works. If it still does not work you can assume that it no longer works. I'd would then call dell let them know and if your still under waranty they will send you out another KB.
    Nov 02, 2007 | Dell Inspiron 6400 Notebook
    E-Machines eMachines Desktop PC Logo
    42 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
