Question about Video Game Consoles & Games
I have a playstation 3. Every time i try to play a game it doesn't work. It either plays for a few minutes and then a cd starts flashing with a question mark in the upper left hand corner. Other times it says there was an error starting the disk.
  • 43 Answers
Sounds like cd lens needs cleaning you can buy a kit to fix this
Posted on Jun 23, 2008
Playing MLB the Show on PS3. Game loads fine, franchise I've been playing loads fine. But once I try to play a game, bar starts as game loads then game cuts off and goes to main PS3 screen.
Is your CD dirty or does it have any cracks? It might just be the problem. Otherwise, it could be corrupt game data. Clean the disc, if it still doesn't work I'd try deleting the game utility data and re-downloading it. Hope this helps in some way or another.
Apr 19, 2012 | Sony Playstation 3 (PS3) Console
My playstation 3 keeps blowing and shutting down every few minutes
the same thing happen to me. the time got shorter and shorter every time i tried to play.I found a website www.videogame911.com that fixes game systems. they were fast and fairly cheap. You can even chat with the person working on your system.
Sep 06, 2011 | Sony Playstation 3 (PS3) Console
Hi there, my Playstation 3 is unable to play the new Rugby Challenge game for long. It gets up to a certain point during game play and then turns off with a red flashing light that follows. But then I...
I have the same problem...im pretty sure its sumfin to do with when my system updated.... Blooding Frustrating ive been waiting 4 a rugby game since rugby 08
Sep 03, 2011 | Sony Playstation 3 (PS3) Console
My play station doesn't recognize dvds or games I put them in and no icon comes on and it doesn't paly
The Playstation 3 is a wonderful video game console, however, with heavy usage, the laser does eventually burn out. The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the game will stop reading altogether (even though movies sometimes still work). Eventually movies will stop working and the whole laser will eventually die.
The following website sells PS3 lasers and also performs repairs:
http://store.richspsxparts.com/pl3isnotrega.html
Jun 17, 2011 | Sony Playstation 3 (PS3) Console
Why does my playstation 3 keep turning off and the red light keeps flashing?
This can can be any one of numerous issues. The first step toward setting everything to rights is to discover what the light is trying to communicate, outside of the obvious fact that your system is not working. First, disconnect everything from the unit, power cable, HDMI, component cables, controller-charging cables or anything else you may have connected.
Allow the unit to sit and cool off for a few minutes before re-attaching all the component wires. It is a good idea to begin with just the connection to the television. You can also try a manual reset of the system if the above steps do not work, simply press and hold the power button for ten seconds.
If none of the above works, you are dealing with a serious PS3 flashing red light issue. This could be a faulty power supply, dead hard drive or malfunctioning CPU just to name a few. You will need to check all these components out and determine if they are still functioning correctly. Screwdrivers and a few other common household tools may be required.
How old is your playstation?
Also try this link if you playstation is outside of waranty
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
Playstation light flashing red and playstation not working
Most of the times, you're going to find that this is due to over heating. If you've been playing for a while, shut down your Playstation, and let it sit for about 1 hour. It's best if the room is cooled off as well.If the room is hot, you may want to put a fan blowing toward it, or turn up your Air Conditioning.Check the back of your unit, and make sure that all of the cables are plugged in. What you're going to want to do is take out each one, and blow the inside of the ports with compressed air.
To play it safe, take out the Playstation's hard drive, and place it back in.Once the 1 hour is up, and the Playstation hasn't been running, turn it back on, and see if everything is working. If it is, you're good to go! If it isn't, you may want to consult with Sony.
May 04, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 will light up green then yellow
1. Try turning the ps3 on and off and then hitting eject.
2. Do Not try to open up the playstation. You may do more damage than good.
3. Try to halfway insert another game, cd, or dvd into the playstation 3 and press eject.
4. Here's the one that worked for me. I slid another compact disc into the console almost all the way but still holding on to it and pushed up as I pulled the disc back out. To my suprise another disc began to slide out with it. I had no idea how many discs were actually inside the ps3, but when I hit eject the original game that was in there still would not come out, so I new something still wasn't right. I repeated the process a few more times and low and behold, I had a total count of four, aside from the game. At last, eject finally pushed hubby's NBALive out of the playstation.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
I was playing a game and it froze and shut off. i try to turn the game back on and it doesnt come on. i see a green light, then the light turns white, and the light flashes red. whats wrong?
i will turn on my ps3 it goes to the main screen shows but the game cd doesn't show so i will have to eject an put it in and it would start playing but it will keep freezing then when i'm playing i will beat a level then freeze so it want save every time
Jan 11, 2010 | Sony Playstation 3 (PS3) Console
My PS3 playd cd dvd but not blue ray games
Problem with the laser it sounds like. If you still have the system apart with the dvd drive out, go ahead and replace the laser. You can usually find them on Ebay.
Aug 08, 2009 | Sony Playstation 3 (PS3) Console
Ps3 keeps freezing on games only
Try using a can of air to blow out the fan area. Even though its well ventilated it may be full of dust. It sounds like an overheating issue. Also look into aftermarket fan/cooling solutions, that dont plug directly into the PS3 and have there own outlet power plug.
May 17, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
