Uniden 2.4GHz DSS Cordless Phone w/Caller ID & Speakerphone
Problem for Uniden 2.4GHz DSS Cordless Phone w/Caller ID &...
Uniden 2.4Ghz Cordless Phone usage causes dropped signal
By LiZzIe - usenet poster
I have searched high and low to find out how to get my MN-
700 Wireless-G Base to stop dropping signals when any of
my Uniden 2.4Ghz phones are used.  I tried changing the
channel on the phones - nothing.  I tried changing the
default channel in the Network software that came with the
Wireless unit - nothing ... are there any instructions
that can help me solve this problem as it is becoming
difficult to continue working.   thanks.
Same Problem
Jun 29, 2008
-   I use sbc w/ a 2 wire 1000 HW router for my wireless connection, and it essentially works fine. However when I turn my cordless phone on and off my wireless connection drops for like 30 seconds and then automatically kicks back in. I use a Uniden TRU8885 5.8 GHz Digital Cordless Phone, and my understanding is that these phones should not cause significant interference with most wireless routers. I've tried changing my wireless channel on my router as well with no success. Any suggestions or further changes to try? Or any different routers or cordless phones recommended that might not cause such problems?
Thanks,
ST -   aa35360
Nov 06, 2007
-   I just purchased a 5,8 gig cordless phone and it still knocks my wireless router off line, why? Is there a cordless phone frequency that is available to stop this from happening?-   Guest
Best Solution
posted on Aug 11, 2005
Helpful)
Chandler
Rank: Apprentice
Rating: 0%, 0 votes
Move the 2.4 Ghz phones as far away as possible from the 802.11
networking hardware.  Also make sure they are not between the router &
any of the wireless clients.
The problem is that the wireless specification for 802.11b & 802.11g
says that the output can only be up to 1 Watt while your phone is most
likely kicking out double or triple digits on the wattage.  That is
where the problem comes from.
Another option is switch to either 900 Mhz of 5.8 Ghz only phones (most
of the 5.8 Ghz phones still use the 2.4 Ghz frequency).
Was this helpful?
Yes
No
Solution #2
Helpful)
Ranny
Rank: Apprentice
Rating: 0%, 0 votes
I was having this issue with my GE Microwave... Meaning I
couldn't work in the kitchen (by the coffee pot!) when
the microwave was in use! We just purchased a GE 2.4 Ghz
phone system and now I am hooped when ever the phones are
in use!!!!!!!!!!!
mentioned.  ;-)  Take a look,
Was this helpful?
Yes
No
Solution #3
posted on Aug 01, 2007
Somewhat Helpful)
bounty1975
Rank: Apprentice
Rating: 74%, 8 votes
use a phone filter on all phones and any and every thing that has a phone line going to it. works for me every time.
use the DSL phone filters at walmart
Was this helpful?
Yes
No
Solution #4
Somewhat Helpful)
Bray
Rank: Apprentice
Rating: 0%, 0 votes
    Well, I understand his plight ... The Uniden 2.4GHz phones are
*particularly* nasty, and there's simply no way to avoid being knocked off,
no matter the placement.  My wife, in the kitchen with the basestation, can
knock me off when I'm 4 feet from my MN-700, which is located an easy 40
feet away.
    Lost cause ... most of the Uniden 5.8 GHz aren't any better, save the
ones OEM'd by Vtech.
Take care,
Mark
Was this helpful?
Yes
No
Solution #5
Not Helpful)
Duke
Rank: Apprentice
Rating: 0%, 0 votes
    Yeah, that's one of the V-Tech OEM units I mentioned.  ;-)  Take a look,
and you'll find the identical phone as Philips, Motorola and VTech.
Mark
"Barb Bowman [MVP-Windows]" <b @nospam.com> wrote in message
Was this helpful?
Yes
No
Solution #6
posted on Apr 14, 2009
Not Rated)
daramir9999
Rank: Apprentice
Rating: 0%, 0 votes
I have 2 cordless phones: a 900Mhz Panasonic & 2.4Ghz GE
Panasonic doent give full sound quality over range BUT boesnt kick out my WLAN, the GE gives sound quality but will kick my ( or maybe your) WLAN.
Sol: Go for a 900Mhz phone its not that bad
Was this helpful?
Yes
No
Solution #7
posted on Jan 20, 2008
Not Rated)
rlbstein
Rank: Guru
Rating: 87%, 175 votes
I'm not thinking a phone filter is going to work due to the fact they only filter out noise on the phone system and not the wireless transmission. There is no real way to prevent them from reacting to each other. My only recommendation if changing the channel on the router to say 1 or 11 doesn't work, a change to a 5.8ghz phone may be an only option. Placing DSL filters on your phone lines will help if your DSL modem is dropping off, not your wireless router.
Was this helpful?
Yes
No
Solution #8
posted on Dec 13, 2007
Not Rated)
behaley
Rank: Apprentice
Rating: 0%, 0 votes
I am having a similar problem. I have a GE 25951 5.8Ghz, and a Uniden EXP741 2.4 Ghz phone that interfere with a wireless interent service. I have DSL filters on all phones and it doesn't help at all. I also have a Uniden EXP370 900Mhz phone that doesn't interfere even though the service provider says that is the only phone that can interfere Any suggestions..
Was this helpful?
Yes
No
Solution #9
Not Rated)
Charlie
Rank: Apprentice
Rating: 0%, 0 votes
that has not been my experience at all. i've got
http://www.uniden.com/product. cfm?product=TRU8885-2 and three
satellite add on units and none of my wireless is impacted here.
Barb Bowman
Expert Zone Columnist
http://www.microsoft.com/windo wsxp/expertzone
MS-MVP (Windows)
Was this helpful?
Yes
No
Solution #10
Not Rated)
kioner
Rank: Apprentice
Rating: 0%, 0 votes
I think that's one of the few models they make that doesn't use 2.4 Ghz.
Was this helpful?
Yes
No
Popular Solutions for Uniden 2.4GHz DSS Cordless
Questions and Unsolved Problems for Uniden 2.4GHz DSS Cordless
Do you recommend Uniden 2.4GHz DSS Cordless Phone w/Caller ID & Speakerphone (E26060)?
Answer
Answer
where can I get a replacement hand set for this model? Is this model digital? Will any 2.4G phone... (More)
Answer
I have a uniden dct 6485 with a base handset and three additional handsets. I now have two handsets... (More)
Answer
cannot adjust ringer volume .both sets ring at full volume
Answer
When making calls using Skype out,testing on echo 123 and all other settings is fine,sound card... (More)
Answer
The base unit is showing an error code E1. I can't find anywhere in the handbook what this stands... (More)
Describe your Phones problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Phone Experts
Top Telephone Repairmen
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
