Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Cobra 29 wx st
I am needing to know where do i adjust the dead key at mine is keying a 5 and swinging backwords. It has an echo board and was peaked and tuned by a pro but something has went wrong since i guess.
    Problem Solver:
  • 12 Answers
Take it back to your 'pro'. Let him fix it.
Posted on Aug 14, 2008
Is it possible to convert the cobra 29 wx nw st sound tracker cb to 10 meter amateur band?
No it cannot. If you want that buy a Ranger or a Galaxy.
The 29 can be altered to increase modulation and turned down in power to match it to amp for increased output of power.
Set to dead key a watt or so with a 100 watt amp it would dead key low and swing to 80 to 100 watts pep.(peak envelope power)
Mar 16, 2012 | Cobra Radio Communications
Cobra 29 modulation modification
did you make sure the caps stripe is facing the back of the radio? If not, its the wrong way.
Also, don't use a 1/4 watt resistor because it will get too hot for it to last. use 1/8th.
changing the cap size will not change output, however it will change the tone. Bigger the cap, the deeper the tone of audio.
to be honest with you, high output mods are worthless in these radios. they are fine with out them. mosfets are unstable and are very dirty transmit finals. As well if you are planning to use a linear you may hit it too hard unless its a high drive, in which case you will need more then 35 watts swing to drive it fully. A stock cobra 29 that has been peaked and tuned, then the swing mod put in, 220uf e cap and 100 ohm resistor, which should give you about 2 watts, should swing to about 27 watts, and kick an amp in the pants.
I run a cobra 29 in my blazer with a dave made 5 pill, and I key on 6 pills and I near keyed on a 2x8. very close. All that I have done to the radio is peak and tune, (of course I have a few tricks with that up my sleave which I don't usually share with just any one.) and variable power, wich will control the dead key, which is basically a varible swing kit. I run it just under 2 watts, just enoug to get a 125 watt dead key out of the amp. The amps swings over 920 watts.
any more swing from the radio will beat up the pills in the amp.
Jan 06, 2010 | Cobra 29 LTD CB Radio
I have a cobra29 wx nw st. its been peaked and tuned, an echo board installed, and soundtracker override when i key up if my mic gain is over 1/4 the way up it makes an awful racket what do i do?
is there talk back installed? if so its probably too loud. You are getting feed back. The talk back should be low, just enough to hear it to check echo. 470 ohm resistor is perfect.
Jan 04, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 classic "swing kit" ?
A swing kit is nothing more then a Cap and a resistor. There really isn't a different way to do a swing kit, unless you do variable power, which you don't need unless you are going to run a linear, and even then you can just set the dead key with a swing kit.
you need a watt meter, preferably one that reads peak and average watts. If not, average will be find.
Open the bottom cover of the radio. Hook the radio up to the watt meter, use a dummy load or have it hooked to the antenna. Never key the radio with an antenna or a dummy load.
Find VR4. Its toward the back right of the radio. Turn it all the way to the left. That increases your modulation.
Next find L14. it is at the back in front of the final resistor. While making a steady sound into the radio, just make an ahhhhhhh noise. Back the slug out of the tank until the needle hits peak. Don't move it out any more or you will over bias the final.
Now you will need a 220 uf electrolytic cap, and a 100 ohm 1/2 watt resistor, both of which you can get from radio shack. (this is your swing kit.
To the right of the tank slug is a jumper maked JP36. Us soldering wick to remove the solder and pull out the jumper. Now put the cap in it with the stripe facing the back of the radio.(that is very important. the other way you will blow the radio.) Solder it in place and cut the extra leads off. Now on the back of the board were you soldered in the cap, solder the 100 ohm resistor in between the 2 points.
The amount of resistance determines you dead key. you will be at about a 2 watt dead key which is good for swing and if you want to run a linear. The higher the resistor the lower the dead key, and the lower the cap, the higher the dead key.
That is your basic peak and tune with a swing kit.
Dec 23, 2009 | Cobra 29 LTD CB Radio
Installing a astatic echo board in a cobra 29 nw please help
http://www.cbtricks.com/ Here is the best site to modify Cbs on the web as well as fourms to help answer questions.
Jun 14, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Trying to hook up a astatic echo board
Looking at the plug from inside the radio, with the nub facing downward, from right to left you have pin1 pin2 pin3 and pin4.
1-Shield
2-Audio
3-Transmit
4-Receive
Colors are
1- Red
2-White
3-Blue
4-Black
Mar 24, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 wx st
IF YOU CAN RECIEVE THAT IS A VERY GOOD SIGN THAT YOUR SWR MATCH IS OFF....I DONT KNOW IF YOU MATCHED UP YOUR RADIO WITH YOUR ANT.IF NOT YOU CAN BUY A CHEAP SWR METER @ RADIO SHACK...CHECK THAT YOUR COAX CABLE IS OK TRY TO REPLACE THE COAX......GOOD LUCK
Feb 14, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Echo on cobra 29
When you purchase an echo board, the instructions come with them.
If you need any help, don't hesitate to email me at rollincbmods@yahoo.com
Dean Pitts
Rollin CBs
Aug 25, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Echo on a cobra 29 nw
Dean Pitts
Rollin CBs
Meter and St lights
The backlit nightwatch lights can not be repaired, they are fiber optic lights that are ran through the faceplate by the factory.
As for the squealing, the normal way talkback is installed on these radios is to solder a resistor, 68 oms up to 100 ohms, from the PA to the External speaker on the solder side of the PC board. The more resistance, the lower the talkback volume. Yourse is probably squealing because the resistor is breaking down, I just fixed a radio 2 days ago with the same problem. If you want to remove talkback, just open the case, flip it tothe solder side, and remove that resistor that was installed, or you can replace it with a new resistor and still have talkback.
The meter is fairly easy to replace, you just need to get a new meter, make sure it is one for the Cobra 29 (it will have the 3rd line to show SWR reading, which the Cobra 25 does not). You remove the case screws, the face plate screws, and then remove one screw and loosen the other that hold the meter inplace. You will have to solder the two wires to the new meter, observing which post they came from, this will determine the direction the meter swings. You just remove the light bulb and put it in the new meter casing with the rubber stay. This will be self explanatory when you open the radio.
Now for the dead key. It may have had a swing mod done, which drops the dead key down a couple watts. This is actually a good thing. If you have a lower dead key, this will allow you a larger range of power to swing. You can tell if it has had a swing mod by looking at JP36 to see if there is a jumper or a Capacitor installed. If there is a capacitor, the it has been done. To change back to factory, remove the resistor that was soldered to the solder side, across the capacitor, then remove the capacitor. Now just install a jumper in the place. Here is a link to the Modification Instructions, so you can get a better understanding:
http://cbradiomagazine.com/March%202007/Cobra%2029%20LTD%20Super%20Modulation%20Modification.htm
If I left anything out, or you have more questions or need further clarification on anything, don't hesitate to email me rollincbmods@yahoo.com.
Dean PItts
Rollin CBs
Aug 07, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
347 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
