Question about Refrigerators
Refrigerator not cooling
A refrigerator about 2 years old was in storage over winter.
plugged in, compressor runs but not cooling at all.
My fridge and freezer just stopped cooling all of a sudden. I hear the compressor running and every couple of min there is a clicking noise. Is there a reset switch or something that I can do to start it working again? The lights are working but the freezer and fridge are room temp.
Posted on Sep 21, 2008
Well... not being a pro... I do know that 1 of two things probably happened. When the gas is not cooled for a prolonged time, it could slowly leak out. When the refrigerator is then switched on again, the compressor will run but it will not cool down.
The other possibility could be related to the transport/moving of the appliance rather than the storage. If a refrigerator is switched on to quickly after it was moved/transported, compressor oil could have flown into the system and did not flow back down yet when it was switched on. This might also result in the appliance not cooling down properly.
Posted on Jun 23, 2008
Not cooling sat in storage 1 year get it home and compressor runs and no cool
Hello Jim;
My name is Peter. I am a retired field service refrigeration technician.
I would professionally rank Amana at the top of the list for reliability and low maintenance.
If you read your owners manual it states your unit must be stored in a controlled environment. Otherwise your warrantee is void.
I have made service calls on units that were less that a year old. They were in a garage (Not controlled environment) and the warrantee was voided.
What happens is the drastic changes of temperature from winter to summer expands and contracts the brazed seal system joints and these joint leak.
Also, what happens is the condensate from humidity corrodes the electrical components as well as the control boards.
You can call a local service company to check out what needs to be replace. You are probably look at a $350.00 + service call, if it can be restored.
Mar 01, 2016 | Amana Refrigerators
Frididaire fridge mod.#FRT21IL5DBA 4 1/2 yrs old. In outside storage room of carport. Stopped running after stretch of low 20's temps. in winter of 2009 Unplugged it, checked coils. Plugged it in when...
Well it should be fine when it warms up, these are not designed to run in anything below 60 degrees, when the temp gets too low it confuses the thermostat and it shuts everything off, as long as the room is above 60 should work fine.
Sean
Mar 30, 2011 | Frigidaire Refrigerators
2 year old LG refrigertor doesnt cool inside is warm and the bottom freezer doesnt work either. outlet is ok. the light inside the refrigerator works.
Your run capacitor is bad which is the plug attached to your compressor or you have a leak in the system. If your compressor is not running after you put a capacitor on then your compressor is fried. Good luck. Rate me if I helped you!
Aug 27, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
Fridge 14 yrs old. Unplugged for 2 yrs - now won't cool.
if u can hear the compressor going , then dont worry about fixing it , it would need to be regased , not worth it too old, if u cant hear the compressor going then it wud be a cheap fix wud need a new thermostat or a defrost timer
Jan 31, 2010 | Fisher and Paykel Fisher Paykel 21768 -...
GE Eterna stopped cooling. Not even 2 years old!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. The noise if you listen close is probably the klixon cycling because the compressor is hot. If the condenser is plugged (real dirty), sign of a clean house, and/or the condenser fan is bad you will not get cooling. If the condenser fans operating properly and the fans inside the freezer and refrigerator are operating that would indicate serious problems assuming the compressor is operating.
Good Luck,
Gilshultz
Dec 01, 2009 | GE Refrigerators
11 years old. Just stop cooling both freezer and
hello mam
the compressor of your refrigerator is out of service and should be recharged by the refrigrant so to do this work please call the engineer and check the work to be perfect and if he dont do it you should buy a new one.
Sep 27, 2009 | Refrigerators
Frige will not cool, have installed a t-stat. appears to have power to th eeye brow board. also installed a new coolant unit 3 years ago. the fridge worked whenput up for the winter but had to tap on the...
If you mean that you installed a compressor or put refrigerant in it, the unit that is, it could have a small leak and when you "put it up for the winter" it leaked out. When refrigerant is under pressure and on it will barely leak out if you have a small leak. They can go without a charge for a long time, but when you turn them off if they have a leak it will all leak out. Make sure you compressor is on and running. Once you put a refrigerator in service it is not really wise to "put them in storage." If you can keep from putting it in storage it would be better to leave them running at a little higher temperature setting. You won't be getting in and out of the unit as much because you won't be there to use it so it will not use as much electricity, but they are ment to stay plugged in and running once they are put into service.
May 12, 2009 | Refrigerators
My freezer is about 2 years old, but has been in storage for about a year and a half. The green light comes on, and the motor is running, but it will not get cold or even cool.
Hi ndntwiggy,
Ngafm at your service
Your said,your freezer is about 2 years old, but has been in storage for about a year and a half.
And the green light comes on, and the motor is running, but it will not get cold or even cool.
When a compressor is not run for more than a year, or 2 years there is a possibility that the seals dried out from non use and the freon leaked out.
Compressors have oil in them that when run even once a month will lubricate the seals and keep them soft and moist! .
Just like in the older cars from the 1960's or 70's the air conditioners had to be run once a month even in the winter to keep the seals lubricated or they lost the freon!
Then they started to make the defroster turn the compressor on as to lubricate the seals every time it rained or snowed and you needed the defrosters and this serviced the compressor as in todays cars.!
So you need service to fix it and more than likely it's out of freon refrigerant .
Let me know your end results.
ngafm
Please give me a good rating for my accurate advice,
before you sign out of our site.
thank You ngafm
Sep 09, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Refrigerators Logo
440 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
