Question about Canon ES10V Camcorder
Camcorder is dead, need to get the tape out!
This Canon ES10V is completely dead, won't power with a cord or battery, and one of my tapes is still inside. I need a way, schematic or illustration, to get the cassette out manually. I have already removed the tape door and everything is exposed, I just don't know what to do next to get the tape to pop out. The camera means nothing to me, I just want the tape inside so I will take whatever action needed, just need some direction.
Again, the camcorder is DEAD, WILL NOT POWER UP BY ANY MEANS, need to MANUALLY remove the cassette.
  • 2 more comments
  • kim747 Jun 23, 2008
    I will smash this camera to get the tape out if needed, I am not looking for a clean or delicate way to do this. I want the tape out by ANY means, just need to know what to push or take off. Again, I don't care what happens to the camera, it is trash to me, I just want the tape out.
    Good link, still looking for more solutions that would pertain specifically to a Canon ES10V.
    I forgot to mention the tape is still around the drum. I don't mind taking the camera apart until there is nothing left, but I don't want to damage the tape, it is footage of my son when he was 5 years old so it is very important to me to find a solution that will allow me to salvage the tape with minimal to no damage. I am not concerned with salvaging the camera though.
    I thought there might be a lever or something that can be released allowing the carriage to lift up and open, I've been jiggling stuff but it seems so tight and doesn't want to budge.
    This was the best one so far, thanks!
  • 426 Answers
If the camera MEANS NOTHING to you then take a screw driver (flat head) and carefully pry the door off, then when you see all the metal hinges and things of that nature, take a pair of vice grips and twist them right to left, and up and down, until they snap off then if the tape is still engaged in the recording mech, take a screwdriver and CAREFULLY push the wheels up while using another screw driver to pry the BOTTOM of the tape out, you may have to pull the ribbion out of the tape.... but just be careful not to rip it, then unwind the tape from all pulleys, rollers, and heads hope this helps a little
if you have any questions please feel free to email me at fixya at whypayforhelp (put a dot here) org
Posted on Jun 23, 2008
  • 2 more comments
  • Lee N.
    Lee N. Jun 23, 2008
    a dremel will work wonders for grinding carefully around componets that if destroyed will ruin the tape, if you tear the tape dont freak out simplytape them back together you will lose abour 1.8seconds of film
  • Lee N.
    Lee N. Jun 23, 2008
    can you send me some close ups of the camera? as to what has been done then i will circle what to remove :)
  • Lee N.
    Lee N. Jun 23, 2008
    please rember that a tft rating when something is still being discussed
    discourages alot of people because these ratings hurt us...
    ~Lee
  • Lee N.
    Lee N. Jun 23, 2008
    if there is a lever i think it might be just a little to late for it to function, but there is usually a pinhole somewhere around the crack where the door and the case of the camera meet, with the tape still engaged it wouldnt do anygood
    President:
  • 1,257 Answers
Problem : I cannot eject the tape from my digital video (DV) camcorder.
Cause :
No power source or depleted battery pack
Solutions
  • The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack.
  • Once the power source is available, some models require manually unlatching and opening a cover.
  • When the cover is fully open, the cassette will eject automatically after a few seconds.
  • If the tape still will not eject, seek assistance from a Canon Service Facility.
Did this article answer your question?
  • 3,037 Answers
First take off the outer panels which should be held in by screws. Then go to the metal assembly holding the tape in and force it open the way it would open normally. You can take a pliers and start ripping it apart if it just won't move but with enough force possibly with a flat-headed screwdriver to pry it, you can open it up the way it is designed to open with power. Most likely you have a loose or broken connection from the power supply which can be fixed if you want to salvage this camcorder. Let me know if you have any questions while doing this
  • Benjamin Patri
    Benjamin Patri Jun 23, 2008
    Since the tape is still around the drum, you will need to remove ALL of the outer panels and separate the left and right side of the camera. The camera should split down the middle and allow access to removing the tape from the drum
  • Canon Master
  • 6,487 Answers
Check this link it will hep you http://www.fixitclub.com/Electronics/Video_Camera.shtml
Hope that helps....
  • Mark Gil
    Mark Gil Jun 23, 2008
    No problem hope you're find the exact one...
  • 725 Answers
I would not recommend trying to remove a tape that is stuck Because the eject and load mechanism is controlled by a motor and you have to supply voltage to in the correct polarity to get the camcorder to take the tape in or eject it, that means that you would have to disassemble it.
That is the case with all camcorders - analog, digital, new or old. If you need the tape I suggest sending it in to a shop If you can do the repairs yourself
Dismental the camera. Try to locate the power board. have a look at the components near the battery connector or the power connector. there you will be able to locate 3 to 4 safety fuses. check the continuty. if found open replace it or jump them and and try to eject it.
you can also try to locate the motor for tape deck loading mechanism. Remove the flex ribbion connector of the motor from the pcb, then try giving 3 volt supply from an external device to the motor in both the direction. in one direction it will move the deck outward, but be carefull when the cassette is being ejected a little portion of the tape may get damaged.
Posted on Jun 22, 2008
2 Suggested Answers
  • 43 Answers
SOURCE: Camcorder is DEAD, need to get the tape out!
most cameras of this type have a series of cogs inside that u can manualy turn by hand or by using a small screw driver,wich will inturn open casset mechanism you need to have a good look and you will suss it out i have done this many times with camcorders dvd players and vcrs, take care andy hope this helps
Remove tape from dead camcorder?
I think the battery failed, I would replace the battery. You can buy the battery by number (battery info is printed on the battery) on eBay.
Mar 23, 2017 | Canon Optura 50 Mini DV Digital Camcorder
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
Canon charge light blinks 7 times
If your Sony camcorder displays a tape transport or mechanical error code always try resetting the camcorder. This is done by removing the battery or ac power, wait 10 seconds, reapply the battery or ac power and try again. If it still goes into error try another tape. The camcorder will not always display an exact error code. Sometimes you may see an error message such as, "Reinsert the cassette", on the LCD screen. This is the camcorders way of saying, "Take the tape out and try again." Try reloading the same tape as well as a new tape. If the camcorder is still going into error this means it is time to send it in for service or repair.
The camcorder may also sometimes display a "Reattach Power Source." This is the camcorders way of saying,"Try resetting my system,so I can try again." Many people mistaken this error and think they have a problem with the battery or ac adapter. This is not true and has nothing to do with your battery or ac adapter. Reset the camcorder by removing the battery or ac power, wait 10 second, reapply the battery or ac power. If the error reappears the unit needs to be serviced or repaired.
Jan 23, 2013 | Canon VIXIA Video Cameras
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
My camera is jammed up and won't eject the tape. Any thoughts? When I plug in the power cord it won't even power up???
Sounds like you have a "dead" camcorder. This can be caused by a circuit protect (tiny fuse) being blown or a bad board. This will need to be repaired by an experienced technician. <a href="http://www.austintelstarservices.com">www.austintelstarservices.com</a>
Aug 30, 2010 | Canon Optura 50 Mini DV Digital Camcorder
Jun 22, 2008 | Canon ES10V Camcorder
Removed mini dv tape, reinstalled mini dv tape... cassette wont close, all power lost!
internal power supply fault, unit needs to be checked by a panasonic technician.
Jun 13, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
C:31:30
FG fault when starting capstan.
Make sure battery is fully charged or a/c cord is used. Turn power on, and push reset button, try to eject tape again. Your capstan motor may be dead.
Jan 03, 2008 | Sony Handycam CCD-TRV318 Camcorder
Tape deck won't eject tape
The tape might be wrapped around the head or the capstan. The mechanism is delicate so you risk more damage by trying yourself - check with some of the repair shops on the Fixya home page for prices to remove the tape.
Dec 17, 2006 | Canon ZR10 Mini DV Digital Camcorder
Canon ES10V Camcorder Logo
629 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
