Question about Acer Aspire 3680 Laptop
Operating system not found
You suggested resetting the memory to fix this problem:
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM.
Operating System not found
How do I reset the memory?
Laptop is saying no audio output device installed
Posted on Jun 25, 2008
    Sergeant:
  • 324 Answers
I probably meant to say "reseat" the memory. Just remove the memory module(s) and reinsert them in their slots. This problem can also sometimes be resolved by reseating the hard drive. I had this happen to me just the other night. The laptop slid off of my lap and fell to the floor. Just fell about a foot and a half, and didn't hit all that hard. Kinda partially caught it as it went. But the laptop didn't like it and I had a message of "Operating system not found". Reseating the hard drive had me up and running in about 30 seconds.
Ron-
Posted on Jun 23, 2008
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM Operating System not found Acer Travelmate 5720G
This error is a result of your computer not finding the operating system. This is usually the case when the hard drive has failed. You will need to take the computer to a technician to replace the hard drive and have windows reinstalled.
Mar 06, 2011 | Computers & Internet
PXE-E61 Media test failure, check cable PXE-M0F
There are two things that could be a problem. The BIOS settings are corrupted, or the hard drive system has a problem. In order to fix the BIOS problem, at boot up you'd hit F2 (or whatever key is required to enter setup). Get some paper and pencil and go through the BIOS pages and mark down anything that is not a default setting. Find the location to reset the BIOS to default settings and perform this action. This will overwrite your BIOS settings and remove any corrupted data. Now, when you reboot, go back into the setup and set all of the settings to the choices you marked down before.
If this does not fix your problem, your hard drive control system has a problem. It could be as simple as a ribbon cable being loose or as bad as the controller section on the motherboard has gone out. Another possibility is the hard drive has given up and needs to be replaced.
Feb 09, 2010 | Microsoft Windows XP Home Edition
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
PXE-E61: Media test failure, check cable Pxe-M0f: Exiting Broadco
PXE-E61: Media test failure, check cable (of the HARD DISK pls)
pls first check the hard disk seated in the bottom left side of ur notebook u have to take out the 7 or 8 screws first and then take take it out by pulling the connector gently and try to re seat or re fit the hard disk so connector can seat firmly in hard disk and then power up ur notebook if Error persists
then sorry to tell u my friend that ur Hard disk has CRASHED and not giving up files for OS loading kindly replace ur HARD DRIVE and restore ur OS thru backup disk u got
Pls take care of ur notebook from bumps and falls and hard impacts during operation and carrying bcoz the disk inside the HDD is very sensitive and gets damaged easily by impacts
pls rate me FIXYA for my diagnosis
Mar 09, 2009 | Acer Aspire 4720 Notebook
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
Sep 30, 2008 | Computers & Internet
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
Oct 10, 2006 | Compaq Evo Notebook N200 Notebook
Acer Aspire 3680 Laptop Logo
334 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
