Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Ink pooling on phot paper
Kodak Easyshare 5300 all in one printer, I purchase this printer and when I print a photo the color ink pools on the sheet.
    Problem Solver:
  • 15 Answers
1-Deep clean and calibrate the printhead
2-Try a firmware update @ www.kodak.com/go/downloads
3-Try a removal and reinstall of the printhead and inks
If all this fails, call Kodak Aio support : 1-800-421-6699 (USA)
Posted on Jul 09, 2008
Poor print outs of black ink - color is fine - I change the cart. and it stills gves me poor quality prints- I've tried the cleaning process from the menu - now what?
Kodak EasyShare 5000 series
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Apr 15, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Giant blobs of ink on every photo...
If you aren't currently, use the cartridge that the printer's manual says is for photos. Photo paper requires a different kind of ink.
Jun 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodok easyshare 5300 printer/scanner
Print out a demo sheet. Press copy and photo at the same time. If the black isn't printing on this demo sheet, (the eyes on the two kids at the top are all white), you need a new printhead. Your's is probably clogged. contact kodak tech support. 18004216699. Option 1
Oct 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer does not make black copies, it will print colored copies but not black kodak 5300 aio printer will not print in black. ink cartridge new.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer not printing correct colors or black
Close the printer.
Jul 21, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Inappropriate color in photos
Dear,
Please try to re-install the driver of your Printer, i hope your problem will be shortout.
Regards
Jul 17, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Photo paper
1. Never put XtraLife paper from a printer dock in any inkjet printer. This paper is not made for inkjets. The ink will simply spill all over the place.
2. You can use any paper you wish that is inkjet paper but you must set the appropriate settings through the print manager if the paper is anything but Kodak inkjet photo paper. The 5100, 5300, and 5500 all recognize the backprint on the Kodak paper and automatically optimize the settings. Other brands of paper are not optimized in this fashion and therefore must be done manually through the print manager or software.
Mar 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
PRINTING LINES
remove the cartridges and the printhead
do a deep clean by pressing menu>clean printhead
see if it will make a difference then also check your ink levels..
Kodak 5300 aio printer won't print black
It is the print head. Cleaning the heads does not do any good, either does replacing the ink. What you'll need to do is contact Kodak's customer service line and they can replace it for you free of charge. On this site everyone seems to be saying it is consistently the black that stops, however, based on what Kodak said it is possible that either the black or the color can have this same issue.
When you call in they will ask you for your service number, which is located on the bottom left corner of the machine, when you lift the lid (as if you were going to replace the ink). They didn't ask me when I bought it, how much I used it, etc.
They will set up a case for you - it takes 2-3 business days for the print head to arrive. They will provide you with an invoice number as well. Be sure to document it all just incase the head never comes, or if there are additional issues after you receive it (and/or if it doesn't solve the problem)
Feb 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
102 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
