Question about Sharp 27K-S100 TV
Freak accident, won't show 75% of channels now!
My husband accidentally touched the remote (universal) in some weird way, and now suddenly we only get about 20 channels instead of the 50 or so our cable package includes. We plugged in a different TV -- channels are all there. So it's not the cable. Is there a way to reset this TV to its original settings, even if we don't know what's gone wrong??? It's so weird. The few channels we do get are crowded into the first 20 channel numbers and all jumbled up (not on their usual numbers). The universal remote we are using, in case it matters, is called "One For All". I rest the remote to the factory specs and then re-assigned it to Sharp, but that didn't change the situation. Help. Thanks.
I lost the manual to this set, but last night I found the Menu button on the remote. I pressed it and then clicked SetUp. There was an option for Quick SetUp of Cable/Satellite. I clicked that and it was then able to find all my cable channels again. I still do not know how we messed it up by bumping the remote -- especially when it was turned 90 degrees away from the screen -- but this has restored it. Thanks.
Posted on Jun 23, 2008
22 822 cob lux
Chances are that you changed the input setting by accidentally touching the input button on the remote. If you press the input button you should see a variety of inputs to select from, try AV1, etc or HDMI1, etc but not TV. When it shows the cable channel it was previously tuned to, press select and that should fix it
Jul 27, 2014 | Televison & Video
I bought a keyin remote and it actually worked but the thing is i accidentally pressed the PRESET button and suddenly all the channels stopped working. what should i do?
I think you succeeded in resetting the remote. However, no harm has been done, either you select SET and see if you can configure it to work with your gadget or better still you go back to where u purchased the remote and lodge your problem so to assit you. good luck.
Apr 17, 2014 | Universal Remote Control Remote Control
Akira tv universal remote accidentally went into service mode cant reset
Press menu-display-power in sequence on the remote control.
Jan 08, 2013 | Televison & Video
Will not change channels, but volume works.
try numeric keypad, if unsuccessful then try reloading TV code in remote
Mar 19, 2010 | Philips Magnavox Learning Universal Remote
I had a paper for a remote... think it is the phillips universal remote.
it said apex tv codes were as follows: 023 and 741
apex audio is: 068
apex dvd is as follows: 044 146 347 545 547 640 644 740 741 840
best of luck
Mar 07, 2009 | Apex Digital AT2402 24" TV
Help! lost device code list for COMMTEL CONTROL FREAK REMOTE CONT
codes for grundig , 0331,1211,1221,1231,1241,1251,1261,1271,1281,1301,1311,1321,1331,1341,1351,2541,2551,
hope this helps .
Feb 22, 2009 | One For All URC-3021 Remote Control
Remote codes for philips universal
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
May 14, 2008 | Philips Universal PH301S Remote Control
An accidental placing of a channel screen
Does anyone have an answer to this problem or do I just throw the tv and remote in the garbage, really annoying trying to watch the tv with the big number on the screen and cannot get it off using the universal remote, old remote used to take it off the screen but its now broke, thinging the new one would do it, but no.
Thanks for reading.
Feb 28, 2008 | Televison & Video
Sanyo DS31590 channel display
I found the solution to this problem . If someone accidentally hits the recall button the display channel will show on the TV screen, To correct this problem hit the Info Button and the display channel will disapear. This works only if you have the standard cable box. I have another TV that uses a dual mode cable box, tried this procedure with analog RCA TV but it didn't work. Don't know if this procedure will work for all display problems, but it worked for me.
Jan 12, 2008 | Sanyo DS31590 31" TV
Olevia syntaxbrillian flat screen tv model527-S12
go through the setup and have the TV auto programm again. This should fix the problem.
Dec 06, 2007 | Televison & Video
Sharp 27K-S100 TV Logo
381 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
