Question about Zenith A27A23W 27" TV
Tv picture is green
I have a Zenith SR3587DT TV and my color is green. I have a MBR3447Z remote and I can not alter the color what can I do? I have tryed to use the remot to menu to alter the color but the tv does not give me a choice of colors as it use to to adjust the colors, what can I do other than purchas another tv?
YES I HAVE HAD THIS TWICE AND NOW THEY TELL ME THAT THE CARD CAN NOT BE REPAIRED AGAIN. THE CARD HOOKS TO THE BACK OF THE PICTURE TUBE. I CAN NOT FIND A REPLACEMENT SO PUT IN THE TRASH.
Posted on Jul 28, 2008
Too much green dont have orginal remote. Is there
your tv needs repair one of the transistors on the neck board is bad..the neck board is connected to the picture tube end inside the tv..but be care full as it stores very high voltage.if you are not a tech have a tech look at it.
Jul 11, 2010 | Zenith Televison & Video
DVD viewing shows in black and white
you have to change color system of dvd(ntsc, pal,) normally dvd remote will p/n button..press it to change color system,,otherwise u have to change color system of ur tv
Mar 15, 2010 | Zenith Z25X22S 25" TV
Colors going bad on my tv?
The picture tubes in Zenith sets (I assume it's a Zenith since you posted this with a Zenith heading, although it's also true for any set this old) were only expected to last around 7 years. Your description makes it sound like you are missing green, or that the green is just way low. This is a common sign of a bad picture tube. There are other possible causes, but tube failure is the most likely. The low replacement cost for small TV sets makes repairing this one uneconomical.
Get rid of the set and treat yourself to a new one.
Jan 25, 2010 | Zenith SY2068DT TV
No picture at all, black screen, audio works , cant work menu cant see it
sounds like video problem take to tv shop they will address your problem okay good luck
May 02, 2009 | Televison & Video
16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
Apr 09, 2009 | Zenith B27A11Z 27" TV
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color Problem
prob bad crt. blue gun weak. new tv is answer.
Nov 17, 2008 | Zenith B25A74R 25" TV
Zenith TV- greenish color
If you take off the back of the TV there are additional tuning buttons. One is for the focus. I have a model SY2551S and have the green tint problem. Have you resolved that?
Aug 28, 2008 | Zenith C27A24T 27" TV
Tube set zenith tv
This is very typical of a Zenith set.Your picture tube will have to be replaced.One of your 3 primary colors (red,green,&blue) have turned off leaving you with the color of the dominant color.I would heave it.
Feb 10, 2008 | Televison & Video
Blueand dark when picture should be yellow and gold bright
Well there are many causes for this. In the back of your tv there are three different color projectors. One red, one green, one blue. One or more of them seems to be out of alignment. They can be adjusted but it is recommended to be done by a professional as there are transformers in the back near that area that create the high voltage current needed to run the color guns.
Sep 15, 2007 | Zenith B32A24Z 32" TV
Televison & Video Logo
162 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
