Toshiba tv model 32zp18q playing up.
My tv is only 4 years old and has now got the following problems.
you switch it and get no picture.It switches its self off a few minutes later.
10 minutes later you switch it on again, it will stay on.sometimes as long as you want it to,others until it wants to.It also sometimes shows parts of ceefax in any form on bits of the screen. If you try to get ceefax you can only get one page or the lines along the top.
I have disconnected my sky,dvd and video but this makes no difference.
would be most grateful for any advice.
Regards,
Kevan London
    Genius:
  • 1,665 Answers
It may be a power supply or IC chip problem.Circuit is complicated and not suggested to troubleshoot it by end user. It is better to take to an authorized service shop.
Have a look if downloading service manual from link below get some help by troubleshooting tips.
http://www.nodevice.com/manual/newmans/32ZP18P_36ZP18P_32ZP18Q_36ZP18Qrar/get11175.html
Posted on Jun 23, 2008
    Master:
  • 788 Answers
Look here: http://www.archives.repairhelper.com/tv_board_detail154e.html
It sounds like the same problem and since the "ceefax" you mention is handled by the teletext IC it would make sense that it is the cause of your problem. As that article state, resoldering all connection of the QT09 board could solve your problem.
Also look here for the continuation of the above article: http://repairhelper.com/tv_board_detail.asp?identity=4137
  • 6,487 Answers
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.) If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective. Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common). Some simple things to try first: Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!). Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive HV were detected.
Hope that helps........
Picture looks like brightness was turned 100%, very white looking
Last 3 years, you are lucky. It sounds like you are having the problem with either the T-CON board or the main logic board. Parts:
http://www.shopjimmy.com/catalogsearch/result/?q=Toshiba+23HLV87+
Send me picture so I can see what you are talking about, budmrtn@aol.com
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 29, 2010 | Toshiba 23HLV87 23 in. LCD Television
9 year old Toshiba TV. The picture is totally
Symptom shows TV got problem in vertical out deflection section, please check and replace vertical output IC and nearby electrolytic capacitors.
Jun 25, 2009 | Toshiba Televison & Video
Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
No Picture.
I have the same TV, your projection bulb has quit/failed.
A loud pop was heard and the picture has gone followed by a red led fault light clicking on and off.
if your tv is less than 1 year old, and you registered it with Toshiba, you could qualify for a free replacement.
otherwise expect to pay 200.00 for a new bulb from Toshiba.
only good thing is you can replace it yourself, only tool needed is a phillips screwdriver.
you can check EbaY for prices less than 175.00 to 150.00
i am on my 3rd bulb within 4 years....
good luck!
Jun 07, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba tv - no picture
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 04, 2008 | Toshiba 57H81 57" Rear Projection...
Blown bulb
i would look at it this way, what other problems does this tv have, the main one that comes to mind is convergence amp ic's which is about 400 dollars USA this is a very common repair with this set.
now would you stick 900 towards this tv thats 4 years old?
if your looking for a new tv google that make and model to see if anyone has problems with that.
Jan 14, 2008 | Toshiba 40H80 40" Rear Projection...
Shadow on my picture on my tv
hi there, shadow on pic may be on antenna problem, the tunner section or the color section, do some test. ty
Jan 01, 2008 | Toshiba 61A60 TV
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Nov 05, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Portable Grundig TV/vcr combo - screen goes blue and then set switches off.
Hi mcloud Your problem is your video circuit.the component could be faulty or it has lose solder.have a tech look on your set for repairs.good luck.
Apr 25, 2007 | Grundig GF70-600 TV
Have sound and no picture
HI I HAVE THE SOUND BUT NO PICTURE BAT WHEN I BEND THE POWER BOARD OR PLAY WITH IT LEFT OR RIGHT THSN I GET THE PICTURE
Oct 02, 2006 | Toshiba 50HX70 50" Rear Projection...
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
