Question about HP OfficeJet D135 All-In-One InkJet Printer
No color printing.
My color ink cartridge is brand new so I know the ink levels are full. All-in-One printer is still not printing in color. Any other suggestions?
  • roundwood Jul 31, 2008
    Despite new colour cartridge, colour doesn't come through except in lines
  • HP Master
  • 2,794 Answers
Check the advanced settings of the control panel and make sure that color printing is turned on.
Posted on Jun 26, 2008
I put new cartridges color and black in printer. They are in the right places but it only prints black
New cartridges? When checking ink levels does it show FULL? Have you run thru the Maintenance solutions such as CHECK INK LEVELS CALIBRATE PRINTER-CLEAN PRINTHEAD-PRINT TEST PAGE ? But of course each model and brand is prob different . (Mine is A KODAK)Ive experienced this The solution for mine was certainly nothing technical. But it worked..the ink had apparently dried in the bottom of cartridge even though it was new) if you try this wear gloves it could get messy! Take an old saucer put a small amt very warm water on it just enough to reach the 'color holes' on bottom and set cartridge in it for a couple just couple mins my ink started flowing.then I moved it close to rim of saucer out of water for a minute , tapping off any excess water, wiped off with paper towel reinserted and it was fine. Now this may not be the answer to your problem but it wont cost to try and it wont hurt the cartridge. First thing tho I would check INK LEVELS make sure printer recognizes the new cartridge
Dec 27, 2014 | Office Equipment & Supplies
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Installed new ink cartridges mx 300, compatible B&W 40, color 41, printer status still says low ink, printing as if it is low ink. properly installed, tape removed, what i miss? can I check something...
Do you know what?. As a matter of fact,it is not compatible cartridges you buy. It is refurbished cartridges that repackaged with other brand as if this is their product. I say it is original cartridges that once empty and repackaged. So that's why when you install the cartridge the ink level stays low. You can make it sure by comparing it with new original cartridge. Find original cartridge,may be you can borrow from someone,which ink level still full and install on your printer. I am a hundred percent sure ink level will show properly :).
Feb 19, 2011 | Canon MX300 Office All-In-One Printer
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information…....
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Corporate Computer
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Ink level didn't change
s.gif Deskjet 5100 series
  1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
  2. Click Utilities .
  3. Click View ink levels .
    • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
    • If the cartridges contain a sufficient amount of ink, continue to the next step.
  4. Click Printer Maintenance .
  5. Click Clean Cartridges .
  6. Follow the on-screen instructions.
ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
May 29, 2009 | HP Photosmart D5160 InkJet Printer
Lexmark printer always want a new cartridge
What you need is to reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
May 28, 2009 | Lexmark X2500 All-In-One Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
HP OfficeJet D135 All-In-One InkJet Printer Logo
48 people viewed this question
Ben Johnson
