2002 Ford Escape Logo
Posted on Jun 22, 2008
STUCK CD I HAVE CD STUCK IN MY 2002 FORD ESCAPE. IT IS A 6 CD CHANGER
  • mm_sauceda Dec 26, 2008
    My cd player just read cd error how do I get it to work again?
  • Anonymous Mar 15, 2014
    6 disc stuck in cadilac cd changer
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2646
Points
If you are trying to eject the cd and it wont come out and reads error but you can see the cd you are in luck. you can take another cd and hit the eject and slot button and while it is trying to eject slide the other cd in the changer and barley push down on the cd that is stuck...your cd should come out....i have an 02 escape and all it does is eat cd's
Anonymous
Level 1:
  • Posted on Jul 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2646
Points
I had this happen twice just after I purchased my ESCAPE new in 2002. First time dealer couldn't find a problem. Next time I insisted on a fix and they fixed. A capacitor had failed and was replaced in the CD changer.
Anonymous
Level 1:
  • Contributor 43 Answers
  • Posted on Jun 22, 2008
Anonymous
Contributor
Level 1:
Answers
43
Questions
0
Helped
10784
Points
99
You will have to remove and open the changer, and remove cd that way, hope this helps
1 Related Answer
ourhowse
Dar
  • 2007 Answers
  • Posted on Jun 21, 2009
SOURCE: cds stuck inside 2003 ford escape 6 cd
It doesn't always work, but you could try pulling the fuses and putting them back in. You probably have 2 fuses for it.
1helpful
Help!! I have a library CD stuck in the CD changer. I can see it but it will not eject...it won't even acknowledge that it has a CD in the changer. I have tried tweezers, switching CD slots and trying to...
TRY TURNING OFF CD PLAYER.WAIT 10 MINUTES THEN TURN CD PLAYER BACK ON THEN PRESS THE EJECT BUTTON.SOME TIMES CDS PLAYERS GET HOT WHEN PLAYED FOR A LONG PERIOD OF TIME.MY CDS SEEMS GET STUCK WHEN I PLAY CD PLAYER LONG TIME.SOMETIMES IF CD DONT COME OUT .IF IT STICKING OUT JUST A LITTLE.TRY PUSHING BACK IN CD PLAYER THEN EJECT IT.THIS TRICK WORKS SOME TIMES.
2helpful
Got 2002 ford explorer and the 6 cds will not come
OK I am no expert but I have has this exact same problem......TWICE. I just addressed it again this afternoon by disconnecting the battery. Once reconnected the radio "initialized" and I was able to eject all cd's and use the player again. I can only speculate as to the cause but it could be because at least 3 of the cd's contained MP3's burned from my ITunes library. I will stick to audio cd's and see if it happens again!
4helpful
2002 Ford Escape, cd's stuck in 6 CD player..how do you fix that and how do you remove faceplate
i had the same problem. the slots inside the cd player that hold the cds slide up and down according to which one you pick. a couple of those got stuck on mine. i took it apart and got the cd out, but wasn't acutally able to fix it. some of the gears got stripped because i waited to long to fix it and it just ground the teeth down trying to get it to work. you can pick up ford radio removal tools at wal mart, or any car audio store to pull your radio out.
Cds stuck inside 2003 ford escape 6 cd changer/radio. Tried tweezers and cannot pull out. Any suggestions?
1helpful
2002 Ford Escape will not accept CD's
the cd changer is broken and must be serviced by proffesional or replaced. try the local salvage yard for the best deal.
11helpful
6 CD Changer/Radio on 2002 Ford Escape
Check this, it worked for me
http://www.i-hacked.com/content/view/213/45/
Cd changer stuck
I had to take the changer out of the console and get the CD that was hung up. I then replaced everything.
CD changer reading "CD ERRor"
reset your radio by unplugging your battery for an hour and plug it in to see what happens. if not then time to replace. these cd players look nice and all cuz they are 6 disc but dont read mp3 well and get stuck easily with thicker cds
There is a CD jammed in the cd player. (6 cd changer) It is a 2004 Ford Escape
It happens to me all the time on my 2002. Try cycling the load and unload buttons for the stuck CD location. If that doesn't work try ejecting the CD. When the slot door opens, try putting another CD into the slot and push on the edge of the stuck CD.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
