Question about HP Office Equipment & Supplies
Lost access to printer. Did uninstall and reinstall but nothing will print. I had to bypass the connect to printer step to finish the install even though the printer was on and the USB cable connected. How do I connect the printer? Printer is HP Photosmart C5180 using Windows Vista.
I telephoned the 0800 441 147 HP help phone number and spoke with 'Boogie'. He spent a considerable amount of time talking me through another uninstall and reinstall and other suggestions without fixing the problem. He suggested that I buy a new USB cable which I did.The reinstall then completed plus the driver reinstallation and my printer is now operational again. Boogie's patience and assistance was very much appreciated by me as a very non technical person!
A question, the $ amount quoted for registering for assistance - is this $NZ and for what period, ? annually or?
Thanks
Posted on Jun 24, 2008
I have a canon pixma mp 287 printer i have installed the drivers also and it is also not offline but when i am giving command to it then it is showing that printer is not responding.why it is showing like...
solution :
1. Uninstall driver printer and remove Printer USB cable from computer. After uninstall finish, restart printer.
2. Reinstall driver printer (don't connect printer USB cable to computer). Wait for the install process, until message "connect a printer USB cable to computer". After message appear, connect printer USB cable to computer.
3. Wait process install finish and try to print.
Sep 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Tip
How to uninstall and reinstall HP Deskjet D2360 Printer
Hi,<br /><br />I think you need to uninstall and reinstall your HP printer drivers.<br /><br />to do this follow these steps:<br /><br /> 1.<br /> Select Start , Settings , and Control Panel .<br /> 2.<br /> Double-click the Add/Remove Programs utility.<br /> 3.<br /> Select the HP Deskjet D2360 Printer and click Add/Remove<br /> 4. Restart your computer<br /><br />To reinstall HP Deskjet D2360 Printer<br /><br /> *<br /> Make sure that the printer is properly set up, turned on, and ready to print.<br /> *<br /> Check that all cables are firmly connected.<br /><br />For Windows XP<br /><br /> NOTE: You must have administrator privileges in Windows XP Professional to install a printer driver.<br /><br /> 1.<br /> Close any unnecessary programs that are running on the computer using the steps below.<br /> 1.<br /> Right-click any program appearing on the Taskbar next to the Start button and choose Close .<br /> 2.<br /> Repeat step a. until all the programs appearing on the Taskbar are closed.<br /> 2.<br /> Click Start , Printers and Faxes , and then Add a Printer .<br /> 3.<br /> Follow the instructions on the screen to finish the installation.<br /><br />For Windows XP Home Version<br /><br /> 1.<br /> Close any unnecessary programs that are running on the computer using the steps below.<br /> 1.<br /> Right-click any program appearing on the Taskbar next to the Start button and choose Close .<br /> 2.<br /> Repeat step a. until all the programs appearing on the Taskbar are closed.<br /> 2.<br /> Click Start , Control Panel , Printers and Other Hardware , Printers and Faxes , and then Add a Printer .<br /> 3.<br /> Follow the instructions on the screen to finish the installation.<br /><br />If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response<br /><br />Thanks,<br /><br />LETMEFIXIT
on Feb 02, 2011 | HP Deskjet D2360 InkJet Printer
It will only print one page, shows status of printing but dosn't continue to print. I checked the settings and the are correct. I try to canel the print jobs but they won't canel unless I reboot my...
You need to install the latest drivers for your printer. Is your PC VISTA operating ?
First step is to uninstall the software and reinstall the latest drivers from the given link below.
Dell V305 Drivers
If the issue does not resolve even after uninstall/reinstall, try the steps below and it should fix the issue,
This is usually caused by corrupted printer drivers. It's most often seen after an upgrade from a previous operating system when the printer was kept connected and turned on during the upgrade.
Solution: Completely Uninstall and Reinstall your Printer and 'force' XP to see new drivers
Dont forget the step 4
Step 1 Disconnect the printer from the PC
Step 2 Go to the Control Panel and click on Add/Remove Programs. Highlight any Printer Software that is listed here. Select Remove.
Step 3 From the Control Panel, click on Printers & Faxes. Right click the printer in question and select Delete
Step 4 Look at the Toolbar. Select File, then Server Properties. Look in the Drivers tab. Highlight the printers drivers listed here and click on Remove for each one.
Step 5 Reboot the PC. Do NOT reconnect the printer!
Step 6 Go to the website of your printer manufacturer. Look for new XP drivers for your model. Download the correct software. If there are no Windows XP drivers for your printer, try looking for ones for Windows 2000. In most cases these will do almost as well.
Step 7 Run the exe file you just downloaded. It should auto-start the installation program
Step 8 The software will tell you when to connect the printer.
Step 9 Once the software is installed and the printer connected, try a test page. It should be feeling great now!
Regards,
Ron
Feb 15, 2011 | Dell V305 All-In-One InkJet Printer
Getting "printing application has stopped working"messaage
You will need to uninstall and reinstall the printer driver. Please follow the steps given below:
To uninstall:
1. Click on "Start" and "All Programs."
2. Go to the "Lexmark " " Series."
3. Click on "Lexmark Uninstall."
4. Click on "Next."
5. Click on "Finish."
6. Click on "Restart Windows."
To install:
1. Make sure no other programs are open.
2. Insert the CD and wait for the installation window to appear.
3. Connect the USB to your computer when prompted to do so. If an "Add New Hardware Wizard" appears when the cable is connected click on "Cancel."
4. Click on the "OK" button on the Install screen to begin running the software. Follow the prompts and accept the Licensee Agreement to allow the software to load.
5. Once the software has loaded, click on "Finish."
6. Once the software has loaded, you will be able to click "Finish." Your software is now installed.
Aug 24, 2009 | Lexmark P4350 All-In-One InkJet Printer
Printer preferences won't open
To uninstall:
2. Go to the "Lexmark X125 Series."
4. Click on "Next."
To install:
You may copy and paste the web address below to access the Lexmark X125 XP driver:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:346:0:0&emeaframe=&fileID=533
Please use the following steps to download the Lexmark X125 XP driver to your desktop:
1. Select "Window XP" in the drop down list and click on "Download Now."
2. On the "File Download" screen, choose "Save."
3. The next screen will be titled "Save As." Choose to "Save in Desktop" and click "OK."
4. You should see files being transferred.
****Note**** If your browser uses a different file downloading format than specified above, you will need to resort to your browsers help files for downloading instructions. The object of steps 1 - 4 is to download the driver to your desktop. This way it is easily accessible.
5. Once the files have completed downloading, double click on the icon with your file name.
6. On the "Win Zip Self-Extractor" screen click "OK."
7. To unzip the downloaded file choose "Unzip."
8. A screen will then display the number of files unzipped successfully, click "OK."
9. Please follow the on screen instructions to complete installation of your Lexmark printer.
Apr 11, 2009 | Lexmark X125 All-In-One InkJet Printer
Installed with enclosed disc
Looking at the setup guide, it does indeed tell you to not connect the usb cable until prompted by the software. It is Step 7.
Here a link to the setup guide:
Kodak 5100 AIO Setup
Kodak Support has step-by-step instructions for uninstalling and reinstalling the software. Just make sure you remove the USB cable from the computer and reboot before you reinstall.
Here is the support page to begin on:
Kodak Support 5100 Reinstall
Comment back to let me know how it went.
Nov 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
"Finished" not Printing
It is a driver issue. you need to uninstall, reboot and then reinstall
Jul 23, 2008 | HP Color LaserJet 2600n Printer
Re-installation of printer software won't complete
i'd say you may have a corrupted system file..had your computer tuned up lately?
Mar 28, 2008 | HP LaserJet 1020 Printer
Printer not installing correctly
Yes, and install software with printer diconnected fro pc untill new software instal instructs to connect
Also ensure you have not just print drivers but scanning software they are different things that both need to be installed to enable scanning
Oct 27, 2007 | Office Equipment & Supplies
Printer will not copy or scan but will print
Hi John, Even if you have deleted them by accident, you can always reinstall using the CD that came with the printer/scanner. If you want to do a clean install, then you would probably have to uninstall also the printer drivers and start from scratch. You may also not uninstall and set it up again. If you go this route, it is also possible that you will have two icons in your printer folder of the same hp printer. Assuming nothing is wrong with the hp, the scanner drivers and app would be reinstalled and presumably you will have access now to your copy/scan functions. Should like to download the installer/driver for you printer/scanner, it is available at (http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&product=79488&lc=en&jumpid=reg_R1002_USEN). You would have to select your operating system. Hope this works for you. Pls post again how things turn up. Kind regards.
May 29, 2007 | HP PSC 2110 Color Printer
56 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
