HELP ME My CD ROM is not reading any disk I put into it not even the HP recovery disk. I donno wat to do thanks
  • shah_khushi1 Sep 24, 2008
    my laptop is unable to read any CD.When w insert any CD green colur light bllinks for some time then it aslo stopped.
    my laptop is Hp pavillion
    Sniper:
  • 65 Answers
Hi stargazing14..
se dis type of problem comes when lens sensitivity gets low or dere os some dust particle nside lens.....
first take up lens cleaner n cleam urs lens properly....then try to play ur cd.....
if it creates same problem den i m sure dat dere is sm interior problem inside lens....
show it urs pc dealer n told him d lens problem....
thanks....
Posted on Jun 24, 2008
DVD ROM can't read
Normally, a DVD player can\'t read the disk because of scratches or accumulated dust. To clear this problem rid the disc you\'re using from scratches and dirt.
Dec 01, 2013 | HP Touchsmart Iq804 Drivers Restore...
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
How do i restore my hp pavilion dv 5000 to factort setting?
There should have been a recovery disk created or included when you bought a laptop. Insert disk if you have it and restart your computer with the recovery disk in the CD drive. Make sure all your documents and personal data are backed up. When the computer restarts it should start restoring your computer to the factory default. There will be a wizard to guide you through the process.
If there is no disk or got lost,then follow this steps:
1.Save any files or folders on your computer with flash drives. Drag and drop files onto the icon of your flash drive.
2.Go to "Start" > "Restart" to reboot your netbook.
3.Hold down "Alt" and "F10" when you see the logo on the screen. The recovery menu will load.
4.Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your computer back to factory settings. Follow the instructions on the screen.
5.Choose your time zone and language when the customization menu appears. Reboot when you are prompted.
6.Restore your saved files from the flash drive.
hope this helps,Goodluck..pls response with your rate and testimonials below for further issues..thanks
Feb 23, 2011 | Computers & Internet
I have a compaq f756nr that has Windows 7 OS installed on it. It appears that the disk driver is missing because the computer will not read any disks that I put into it. It's like I don't even have a disk...
In order to recover the Operating System using Acer Recovery Media please perform the following:
  1. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
  2. Using the keyboard arrow keys, arrow over to Boot.
  3. Refer to on screen instructions to set the first device to CDROM.
  4. Press the CD-ROM drive eject button and insert the System CD.
  5. Close the CD-ROM tray.
  6. Press the F10 key, and then the Enter key to save the changes and reboot the system.
  7. The computer will boot from the Acer Recovery Media, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media they may be purchased at our online Acer order form..
Oct 31, 2010 | HP Compaq Presario F756NR Notebook
I have a s3100n hp slim line pavillion and thru hp tech support was advised to do a system recovery. when i tryed to reboot my system some programs were missing and they hp said that i need the recovery...
You must go into the BIOS on boot up and choose to boot from CD-Rom instead of the hard drive. When you first turn on your machine and the HP comes up push F10 key to get into the BIOS. Look for boot priorities and put the CD/DVD Rom in the first boot position (directions on how to move these item up/down are at the bottom of the page)
Then your disks will be useful. Put one in and reboot. It should read you disc and follow instructions from there.
Hope this helps you, good luck
Apr 23, 2009 | HP Hewlett Packard Pavilion Slimline...
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
My cd-rom won't read the disk that i am putting in.
If you have a can of air, blow it softly into the cd-rom to make sure dust isn't causing the laser to act weird. Then try a couple of different cd's to be sure and if the problem still exists, then the cd-rom is bad and it will have to be replaced.
Jan 29, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Factory.settings
According to what you have said, you might have created the Recovery disks after purchasing the notebook.Now you are trying to restore the notebook to factory settings, but they are not working.
Even you have tried to F11 options to restore notebook using the Recovery partition of your notebook.
Let me assist you in this regard.
If the recovery disks are not booting, then we have to check if the issue is with the disks or with the CD/DVD drive itself.
To check that, you need to try to boot with any other OS CD. If the notebook is booting with other OS disks, then the issue is with the Recovery disks itself.
Even F11 option is not working, you have to make sure that D: Recovery is not removed.
For your information, if the issue is with the Recovery disks, then you can purchase the Recovery disks from Hp at very low price.
You can order them from the below link:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=500508
Under
CD-ROM order page - Recovery Discs you can order the place order for Recovery disks.
Aug 09, 2008 | HP Compaq Presario V2000 Notebook
Only reads some disks.
Hi, if the PC's are older than 3 years or the cdrom drives are near it's end of life, it will make problems to read some CDR's. If you recorded the CD's you are trying to read, try recording at less than 4X speed.
Sometimes, even "original" or "silver" CD's will make problems because they are not recorded correctly at the factory.
If the problem is with a CDRW drive, it applies the same theory, the recording laser is damaged or used up. It will not record a legible CD or DVD even if the software says that the record operation ended successfully.
Feb 09, 2008 | HP Pavilion dv6000z Notebook
Ntldr is missing
seems your MBR is damage. but you can repair it if only you can boot in windows cd and entering in the recovery console.
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.    Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.    When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.    If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.    When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.    At the command prompt, type this commands one at a time.
FIXMBR  C:
FIXBOOT  C:
COPY [CDDRIVE]:\I386\NTLDR  C:\
COPY [CDDRIVE]:\I386\NTDETECT.COM  C:\
BOOTCFG  /rebuild
6.    To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
no warranty...you use on your own risk :)
Oct 27, 2007 | Compaq Presario sr1111nx 2.53GHz Celeron...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
