Question about Whirlpool GEW9250 Electric Dryer
Piece of ****
I had an old dryer that worked fine, for 12 years I might add, replaced the element once I think, now I spent about 2,000 on front load whirlpool washer and dryer with stands, hoping for ten years to justify the expense, no like all of you I had originally a PF on dryer screen, for a day or I could unplug for about and hour and plug back in and would work for a load or two, now every day or two it will work for a load, tech came out suggested replacing board told him to much for a gamble glad I didnt after reading these comments, now I'm on the internet searching for a solution, mine right now has no power on board and light inside does not work either. Help anyone
  • 525 Answers
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_alp.php?p_sid=mvr*na7j&p_lva=&p_li=&p_accessibility=0&p_redirect=&p_page=1&p_cv=&p_pv=1.183&p_prods=183&p_cats=&p_hidden_prods=&prod_lvl1=183&prod_lvl2=0&p_search_text=gew9250+&p_new_search=1&p_new_search=1&x=36&y=5
If this doesn't help, post me back and I will do some more research to help resolve your issue.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 25, 2008
Replace Zanussi ZWD12270W faulty dryer heating element
Just for the record, the heating element went on mine too and I'd only used it less than half a dozen times. The engineer said that it went because it hadn't been used enough (it gets moisture inside somewhere). He said if I didn't use it I would have the same problem after it had been replaced. So make sure you dry something every couple of weeks (he said at least once a month).
Nov 30, 2013 | Zanussi ZWD12270 Front Load Washer / Dryer
Need to replace heating element,where to open dryer
Hi Deborah. I d not have this model of dryer, but I did a similar job on my front-loader. First you should make sure that the heating element is the problem; in my case, there was a fuse and a thermal coupling that might also have caused this behavior. If you search around, you should be able to find a troubleshooting guide for your dryer that details how to test. You will need a screwdriver and a multimeter to follow the procedures. The manual should also describe how to do the replacement, but the basic steps should be similar for all dryers like this:
1. UNPLUG IT!!
2. make sure it is unplugged
3. remove the top. Usually held on with screws in the back and tabs in the front
4. remove the front. May have to remove the door first. if you have front-mounted controls, you will need to unplug the wiring harness(es).
5. remove the drum. I didn't think it was heavy, but that is a subjective thing.
6. the heating element will be mounted on a panel on the back wll of the dryer, probably on a piece of material covered with a reflective coating.
7. Unplug the element from the cabinet wiring, and remove the backing surface with the element. you can test the element for continuity with the multimeter. In my case, the element was visibly broken.
8.The element will probably be strung on a series of wire holders; unstring it.
9. String the new element on in the same way that the old one was strung.
10. put everything back together, and if the element was the problem, you should b good to go.
Aug 30, 2013 | Electrolux EIED55HIW 27 In. White Electric...
Life span of a dryer
the first thing you should do is clean out any lint in the exhaust side of the venting area. it could be overheating from that and shutting the heat off too soon.. on an electric dryer the heater part either works or it doesnt. element should be fine in this case i suspect..
Apr 01, 2017 | Maytag Dryers
WD 9900 does not dry
Most all dryers, including combo washer/dryers, have an electric wire coil for a heating element.
I suspect yours has given up ( they usually break in two, stopping the electrical flow). You should need to have the element replaced.
Going to need to take the whole machine apart to fix this.
Be blessed.
Apr 17, 2013 | QuietLine WD-9900 Front Load Washer /...
Whirlpool front load dryer will not start
Does your dryer have a reset switch on the back, usually a small red button, if it does press this and ten test dryer starts again.
Dec 21, 2012 | Whirlpool Dryers
DEGX1 dryer will not produce any heat. 5 years
I have the same model of dryer and the same problem and no experience in fixing any appliances. I took a few screws off the top and the front, opened the dryer by rotating it forward, and found a red button (a fuse or breaker?) close to what I figured would be the heat sink. Pressed the button, it clicked, and decided to put it all back together. First load worked fine, hopefully that was all it needed. Good luck and hope this is all you have to do too.
May 15, 2010 | Fisher and Paykel DEGX1 Electric Dryer
. I have a LG WD12126RD front load washer dryer
This is a heater error. The heater element is open and not working. This is usually the problem but it could be other things also. You need a service call from an LG tech.
Jan 11, 2010 | LG WD-12126RD Front Load Washer / Dryer
No heat, only blows cool air. I think the heater element burned out. The vent likely had a partial plug and the drier smelled really hot a couple days ago. It runs, air flow through it right now but it...
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Sep 13, 2009 | Whirlpool LER5636P Electric Dryer
Trying to determine if it is worth replacing the heating element on a 12-15 year old electric dryer?
Are you kidding me? Light bulbs don't last for 15 years, why would ya think your dryer heating element would last longer. Me I replace the element every time. Todays newr electronic **** is worthless.
Dec 14, 2008 | Dryers
Front load dryer
Remove the front panel to get to it. Once you get the front panel off it is easy to remove the drum and replace the element. First remove the top then the front then you have it.
Dec 19, 2007 | Frigidaire FEQ1442ES Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
187 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
