Question about Garmin nuvi 350 GPS Receiver
Nuvi 350 on off problems
Garmin Nuvi 350 on off switch stopped working. everything else works fine. powers up on usb or with car charger. reset button shuts it off but manual button on top does nothing at all. any ideas?
  • 1 more comment
  • legoland Jun 24, 2008
    I also had the same problem. I just bought it about a year ago. On/off button was dead but when I connected it with battery charger, it worked but I couldn't close it unless I have to press the reset button at the back of Garmin 350. What is wrong with it ?
  • KiminNJ Jul 22, 2008
    Same problem with my Nuvi today. Got to work and it won't shutoff by that upper right hand button. Thanks for the solder solution. I need to check my warranty as I just bought this in Dec 07 - and if not I will show my husband your solution.
  • ledwinsen Nov 30, 2008
    water entered my garmin and i cant get it to start without chargin it! you cant still see the screen? what could be the problem?
  • Garmin Master
  • 2,124 Answers
This is a common problem with the Nuvi series. The on/off switch is a surface mount switch that is mounted vertically off of the main PC board.
The problem is, that there is no support behind the switch, so when you press down the button, the solder leads of the switch are stressed and eventually break off the main PC board. This is a design flaw and could have been easily prevented by wedging a small piece of plastic between the rear of the switch and the SD card housing to give the switch support.
Also, the solder pads for the mechanical connections of the switch could have been made bigger, allowing for more surface area and more solder application.
I have repaired many of these before and I'll be posting a step-by-step procedure on how to fix this and prevent it from happening again.
I must point out however, that in order to make this repair, you will need to have skills in dissassembly and soldering.
Also, please only attempt this procedure if your unit is out of warranty.
If you would like for me to repair your GPS, please email me at KS3R at sharc dot net.
- Jim
Posted on Jun 25, 2008
    Problem Solver:
  • 11 Answers
Hello sharcnet,
Thanks for the solution. As I have also fixed any number of similar problems, your solution is exactly what I suspected the problem to be. I'm quite sure that I can make the repair, but I can't see how to open the unit.
Can you advise how to open the nuvi 350? Also, you said that you intend to post the repair procedure. If you don't already have it prepared, could you give me the short course on the repair? I've learned to appreciate good advice.
Thanks,
Al
Posted on Jul 02, 2008
Thank you very much for your answer
Posted on Jun 27, 2008
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
Nuvi 350 will not run on DC charger
Make sure your DC & AC charger is a OEM charger.
There is a good chance that there is a bad connection on the mini-USB port.
What happens when you plug the unit into the cradle and NOT use the mini-USB jack?
http://www.sharc.net/gps_charger_repair.htm
- Jim
SHARCNET-USA
Apr 19, 2010 | Garmin nuvi 350 GPS Receiver
My garmin nuvi 2255w is completely dead. Will not turn on, the screen stays blank. I plugged it into the car plugin and it does nothing. It was working just fine before now.What could be the problem?
My garmin Nuvi (205 I think) just stopped working...blank screen, does nothing? Was working fine a few hours ago. Car plug in lights up when plugged in but still nothing.
Feb 08, 2010 | Garmin nuvi 255W GPS Receiver
I have a garmin nuvi 350. It suddenly quit. It would not power up. I bought new car charger and wall charger specifically for nuvi 350. Both charger would not power up the gps at all. Is my battery dead or...
I would say this is not a battery problem. A Nuvi will power up even with the internal battery disconnect (done it many times myself ) when connected to an external power source. Please see this link about Dead Nuvi's. Have you tried pressing the reset button behind the antenna?
http://www.sharc.net/gps_dead.htm
- Jim
Jan 18, 2010 | Garmin nuvi 350 GPS Receiver
My Garmin Nuvi 300/350(2 years old) comes on and
I solved the problem by charging internal battery using the 120V. charger that came with the unit. I was not aware, that the cord in car was not charging my Nuvi and that it was running OK. until the battery was low and quit. I have to check this cord. Peter W.
Oct 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
When i plug in my garmin to a car charger it
u need to replace the battery, they last about 2 years on average.
Sep 10, 2009 | Garmin nuvi 350 GPS Receiver
My Garmin Nuvi 710 GPS doesn't switch on
Connect your Nuvi to a PC using a USB and then hold the switch to the left for 15 seconds. It should then power up after a soft reset
Apr 02, 2009 | Garmin NUVI 710 Car GPS Receiver
The voice stopped working on my Garmin Nuvi 350 in mid sentence
what has happened? my etrex said low batteries. I changed batteries. now all I get is searching for sattellites? can anyone help?
Mar 30, 2009 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 wont charge with car adaptor. But charges with ac charger in usb port of Nuvi. Any thoughts? I have another Nuvi 350 that does charge with this ones car adaptor.
Are you using the same port on the Nuvi to connect the car adapter and the ac charger, or two different ones? If not, then the jack could be broken (solder joint, pin?).
Aug 10, 2008 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 System Software Missing
Try this: Hold the power buuton down, you will see on the lower screen the word "Pre Booting - ". Keep holding the power button for about 60 second, then you will see on the lower screen "Booting".
This time, release power button; system will reboot and loading map... again.
I got the same problem, after research on the web. Nick 99990_0 had post this solution on (his Nuvi 660) but it work for my Nuvi 350 too. Good luck.
Minh (NJ)
Nov 10, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
407 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
