Question about Brother MFC 210C All-In-One InkJet Printer
The print head is stuck to the right side of the printer. I checked for paper blockage, I unpluged the printer, I followed all directions in the users manual but nothing I do seems to help . Please advise
  • 1,218 Answers
Check the following Video
Hope this helps you.
Posted on Nov 24, 2010
My Canon printer MP630 has 6A80 error. I have turned off power as shown but with no result! Have checked the manual & tried again without success! Please can you help me?!
I suspect you have had a paper jam and removed the paper. However some still remains inside the machine. Its most probably around the purge unit. When the carriage parks on the right side of the machine, the purge unit rises to cap the carriage so your print head does not dry out. Open the internal cover so you can see the carriage. If it is anywhere other than at the far right side of its travel then kill the power by unplugging from the mains supply. Now the carriage is free to push. push it all the way to the left side. Shine a torch into the printer and you will see the purge unit on the right side. It has two black oblongs of rubber that mate with the print head. There will be paper scraps around it.Or it may be stuck and with a long screwdriver you can push it gently backwards to free it. If none of this helps and the carriage is stuck on the right side then again kill the power and rotate the long black roller that is under the carriage. Do this while gently trying to push the carriage to the left until its free to move then follow the above again.
Dec 24, 2016 | Canon Office Equipment & Supplies
Spotty print
Could be a blockage on the printer head drive belt. Check to make sure the belt is not stripped or blocked.
Oct 18, 2013 | Ricoh Office Equipment & Supplies
Cannot remove the paper jam
To clear the message Paper Jam from the display, follow the steps listed below:
NOTE: images shown below are from a representative product and may differ from your Brother machine.
STEP A. Check for and remove any jammed paper or foreign objects in the machine
  1. Unplug the Brother machine from the power outlet.
    Caution Before you unplug the machine from the power source, you can transfer your faxes that are stored in the memory to your PC or another fax machine so you will not lose any important messages. Refer to the Related FAQs in the end of the page for information. (only for applicable models)
  2. Lift the scanner cover using the plastic tabs or finger holds, located on the left and right side of the machine until it locks securely into the open position.
    Caution DO NOT touch the encoder strip. The encoder strip is a clear plastic strip in front of the white vinyl band (outlined in red as shown in the picture below). If the encoder gets markings or debris on its surface, it may cause other problems.
  3. Verify the location of the print head. The print head is a black square object, located behind the encoder strip. The print head moves from left to right.
  4. Move the print head to the middle using your fingers.
    Caution DO NOT touch the encoder strip (marked in red shown below).
  5. Check for and remove any ripped paper or a foreign object in the left corners or underneath the print head.
    Hint The ripped paper may be very small. Using a flashlight will help you to find the ripped paper.
  6. Turn the machine around and open the Jam Clear Cover (1). Look inside the machine and remove any jammed paper.
  7. Close the Jam Clear Cover. Make sure the cover is closed properly.
  8. After removing all of the paper scraps, Close the scanner cover by lifting the scanner cover to release the lock. Gently push the green scanner cover support down and then close the cover.
  9. Remove the paper tray (1) from the machine.
  10. Place one of your hands under the LCD unit and into the opening of where the paper tray was.
  11. Using your hand, lift the front of the machine approximately 6 inches off the surface.
  12. Look inside the tray areas roof of the machine and a row of black rollers will be aligned across. See picture below.
  13. Look in-between each of the black exit rollers for a piece of stuck scrap paper. (A flash light may need to be used if you are having trouble locating the paper scrap).
  14. Using a pair of tweezers, the paper scrap can be easily removed from the exit rollers.
  15. Place the machine gently down onto the surface.
    • If no paper scraps were found inside the machine, please check the paper in the tray. If the paper is slightly curled, the print head will catch the edge of the paper and tear it. To resolve the issue, the paper in the tray must be replaced and continue to STEP 16.
    • If paper scraps were found and removed from the machine, continue to STEP 16.
  16. Put the paper tray back into the machine.
  17. Plug the power cord back into the power outlet.
    • If the LCD displays the date and time, go to STEP D.
    • If LCD displays the message "Paper Jam" go to STEP B.
- If the print head is on the right side:
  1. Plug the power cord back into the power outlet and wait for the machine to stop making noises.
  2. Press the Stop/Exit key for approximately 5 seconds until the print head moves to the middle.
  3. Unplug the machine from the power outlet.
    Caution Make sure to unplug the machine. The print head may move and injure your hand. Before you unplug the machine, you can transfer your faxes that are stored in the memory to your PC or another fax machine so you will not lose any important messages. Refer to the Related FAQs in the end of the page for information. (only for applicable models)
  4. Examine the right side of the machine where the print head had been positioned and underneath the print head and remove any pieces of ripped paper or foreign objects.
    Tweezers may be used with caution to remove paper scraps or the foreign objects.
  5. After confirm the paper scraps or the foreign objects in the right corners or underneath the print head, go to STEP 6.
Mar 10, 2011 | Brother MFC255CW All-in-One InkJet Printer
Check error
Try the following steps
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTENCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Nov 29, 2010 | Brother M 4318 Matrix Printer
I have a brother DCP-135C with a printer jam. I followed the instructions in the user guide and believe I have removed all the paper but still get the paper jam message. When I unplug then plug it back in...
for this model, normally the paper is stuck behind., you can open the rear part of the printer and check if there is any paper stuck there.
lift up the scanner unit and switch on the printer, does the sound come from the print head side, it could be due to the print head getting stuck... the encoder belt might be damaged...
May 20, 2010 | Office Equipment & Supplies
Last page stuck in printer. I manually pulled the paper free. Printer will not print. Lower two lights blink in phase. Unplugged and replugged. Still same light pattern and no print. inspected inside and...
First open rear cover and make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.Check the carriage lift mechanism for correctly moving. If this not help your printer need service.
Nov 09, 2009 | HP DeskJet 5550 InkJet Printer
I have changed ALL cartridges but 2 red lights flashing. 2nd light just ejects the paper. Cannot see any blockages. Regards Fran
please try the following:
  1. Turn the printer off, and disconnect the interface cable.
  2. Open the printer cover and check for any paper jam or foreign object that blocks that print head movement then remove it.
  3. Close the CD/DVD guide if its open.
  4. Turn the printer back on.
  5. If the error disappears, turn the printer off and reconnect the interface cable. Turn the printer back on and try printing again.
  6. If the error continues, unplug the printer power cord for a few seconds and reconnect it to a different power outlet.
  7. If the printer is plugged into a power strip or surge protector, try plugging it directly into the outlet.
Aug 14, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Paper jam in a Kodak ESP- Printer
i had the printer jam issue when there wasnt a real printer jam.
if you push the print cartidges off to the right, then reach in and push down on the cleaning head that is located on the left on the inside, it pops back down into place and voila, printer jam error message fixed.
Jan 30, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Carriage jam on hp photosmart printer
The print carriage may get stuck on either side or in the middle of the printer. The Carriage Jam: Open Door, clear carriage jam, and then press OK to continue error message may display on the front panel of the all-in-one.
Solution
The print carriage is the device which contains the print head and moves left to right during printing.
Figure 1: Carriage Assembly
To resolve this issue, follow the steps below in the order presented.
Step one: Print a Self Test
Follow the steps below:
1. Press the Setup button.
2. Select Print Report and press OK .
3. The self-test page should print. If it prints a test page, there is no need to follow the remaining steps, as the error message may be false. Make sure the printer now prints from the computer (if installed on one). If it does not print, proceed to the step two.
Step two: Clear the paper path
Follow the steps below to clear the printer of any jammed paper and reset the printer.
1. Leave the printer on and then disconnect the power cable and the USB or Ethernet cable from the back of the printer. Do not reconnect them until instructed to later.
NOTE: Make sure the printer is on before disconnecting the power cord. Failure to disconnect the power cord from the rear of the unit can cause damage when removing jammed paper.
2. Open the top access door.
Figure 2: Opening the top access door
3. Make note of where the carriage is stuck and look for jammed paper. A paper jam can cause the error message and the carriage stall. Some paper may be jammed in different locations than those shown in the photos below.
Figure 3: Paper jammed on the left side
Figure 4: Top view of paper jammed on the left side
Figure 5: Paper jammed on the right side
Figure 6: Top view of paper jammed on the right side
NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the unit.
If the carriage is stuck on the right side:
a. Check for any paper or object that may be restricting the carriage.
b. Move carriage all the way to the left side.
c. Check the paper path all the way to the right side and remove any paper still in the printer.
If the carriage is stuck on the left side:
d. Check for any paper or object that may be restricting the carriage.
e. Move carriage all the way to the right side.
f. Check the paper path all the way to the left side and remove any paper still in the printer.
If the carriage is stuck in the middle:
g. Check for any paper or object that may be restricting the carriage.
h. Move carriage all the way to the left side.
i. Check the paper path all the way to the right side and remove any paper still in the printer.
j. Move carriage all the way to the right side.
k. Check the paper path all the way to the left side and remove any paper still in the printer.
4. Remove the rear access door or duplexer (if installed) from the back of the printer.
5. Check for and remove any paper still in the printer.
6. Replace the rear access door, and close the top access door.
7. Reconnect only the power cable. If the printer does not automatically turn on, press the Power button.
NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
8. If the Power light is on steady, print a self-test page as done in Step one.
If the Power light is not on steady and the carriage is still in a stalled position, proceed to the next step.
Step three: Plug the printer directly into a wall outlet
Verify that the printer is properly connected to a suitable power source by following the instructions below.
1. Verify that the computer and the printer have a three-prong power plug.
2. Remove the printer cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
3. Try the print job again to see if this step resolved the issue.
NOTE: If the printer prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
4. If this did not resolve the issue, proceed to the next step.
Step four: Service the product
If you have completed all of the steps listed above and are still experiencing a problem, service your product.hope this helps
Jan 05, 2009 | HP Office Equipment & Supplies
Brother MFC 210C All-In-One InkJet Printer Logo
426 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
