Back to:
Tags:
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
My model no is GE HSS25GFPJ ALL OF SUDDEN STOP... (by 2 users)
posted by PREM00707646 on Jun 22, 2008
HI
THIS FRIDGE I BOUGHT 2 YEARS AGO AND ALL OF SUDDEN IT STARTS STOP COOLING AND MAKING SOUND LIKE TIK TIK TIK ,
DO YOU THINK YOU CAN HELP, PLEASE CALL ME @201-927-5437 THANKS
I AM IN NORTH JERSEY
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jun 23, 2008
WE R LOOKING FOR TIMER AND CAN NOT FIND LOCATION OF TIMER
CAN U HELP ME
THANKS
DO U HAVE PHONE NO WE CAN REACH YOU,
MY NO IS 201-927-5437
THANKS
Best Solution
Helpful (85)
heymatt
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
If you open the refrig door and the light comes on you have power.
Most likely the defrost timer has stopped working.
The timer is often located inside the refrigerator part of the unit, or under the remove-able face on the bottom of the frig.
You can manually advance the timer with a screw driver or a coin. The place that you advance the timer is a round object in the middle of the face of the timer. You must rotate this part of the timer. The design is such that you can only rotate the timer in one direction.
If you rotate this and the compressor motor begin to work then you can be sure the problem is the timer motor. Sometimes the wire breaks off the contacts that run the little motor inside the timer.
You can buy a new one and replace this quickly.
Do replace the timer if rotating the compressor starts. Rotating the timer is not a fix, it is only a test. The timer is designed to defrost the refrig Failure to have a defrost cycle is bad.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on my model no is GE HSS25GFPJ ALL OF SUDDEN STOP COOLING:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Refrigerators
My Maytag refridgerator / freezer has a problem. The...
GE GSS25JFPCC / GSS25JFPWW Side by Side...
I have a GE GSS22JFMD WW side by side. Yesterday we...
Our Fridge (freezer side of a side by side actually) is...
I can't get water from my water dispenser
I cleaned the elements at the bottom of our BH2055W on...
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
