GE air condioner doesn;t blow cold air
GE Air Condioner
    Novelist:
    Champion:
  • 230 Answers
That is definitely a problem. Make sure that all the related filters and coils are clean. If there is ice forming then wait until the ice thaws after checking the filters and then retry.
If this doesn't work you will need a contractor to properly diagnose the system and check for any recalls or manufacturer warranties.
Posted on Jun 23, 2008
Air condioner not blowing cold air
Do you have a question !
Only testing will find a problem,
surely you know that
Aug 24, 2014 | 1998 GMC Jimmy
Where would add r134a freon at which port
No you don't
You know you have a leak, that
needs to be repaired
It has to go somewhere, doesn't it
Your poluting the atmosphere by
knowing it is leaking
Jun 22, 2012 | 2002 Chrysler 300M
Ruud achiever seer 10 air condioner not blowing cool air
need more info, touch the copper lines going into the unit do u feel any flow? Go outside do you see any fans turning? number of things you can do. Get back to me
Aug 12, 2011 | Heating & Cooling
Security light came onm and car would not start could not even get the remote locks to work and all lights stayed on. We unplugged the battery and left the cra overnight. Went back the next day and hooked...
The security light is a real common problem on GM vehicles. You can fix this yourself, read this link for information, symptoms, and ways to fix it. http://vatspasslockpasskeysecurityhelp.yolasite.com/
The air conditioning probably got messed up when unhooking the battery. Id be looking for a fuse or relay that has been tripped.
Jul 04, 2011 | 2003 Chevrolet Impala
My air condioner throws hot air and air is charged
never getting cold even if you are driving speedy then it is a ferion
if cold while speedy then it is thermostat
if it is a kind of automatic control a/c might be the control
Jun 01, 2011 | 1999 Chevrolet Blazer
Air condioner stopped getting cold
Run truck and turn on A/C check condensor and see if clutch is engaging, if it is that part is good, know how many times does it engage in 1 minute if more than 3 l'd say your refridgerant has escaped and an A/C service will be required.... along with other parts, hole worn seals....
Apr 27, 2010 | 2004 Ford F250
Air condioner climbs to 86 degrees
These latest models rely on a cheap part called a thermister. Older ones used a mercury based cold control. A pc board sends a small amount of power through the thermister to judge the temp. As the temp changes the resistance inside the thermister changes. These el cheapo mexican thermisters are a dime a dozen. They have a quick connect. The thermister must be suspended near the coils but not directly on them or temps will not be judged correctly. Since a thermister is less than $10 bucks i would replace that first before calling someone.
Aug 21, 2009 | GE AJCQ08ACB Air Conditioner
HAVE OUTSIDE AIR-CONDIONER.INSIDE HUM GOT REAL LOUD
sounds as if maybe you have a fan motor about to go out if the noise is that bad you should have a tech look at it as soon as possible due to the damage that it could cause overheating. I strongly suggest you have this looked at soon it isn't all that expensive and could save hundreds Hope this helps
Dave
Jul 16, 2009 | Heating & Cooling
Heating & Cooling Logo
262 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
