Question about Electrolux Kitchen Ranges
Electrolux Induction Cooktop: My husband had a pot boil over, and now the cooktop controls are giving error codes - what should we do?
Power down, then back up. You will be lucky if that fixes it though. I had the same problem here. It is in-warranty so I called Electrolux. Parts came in only after requesting them multiple times. Repairman put them in and they were bad. After a month it is still broken. I was promised a new unit, but little real action. Electrolux is a horror. No way to DIY this thing, too complicated. Cut your losses and buy another brand.
Posted on Aug 11, 2008
Displays error 40. Why won't it turn on?
Hi Dolores, I understand that your cooktop will not turn on after receiving an error code "40". Usually this error code can indicate a communication error between the Induction Module, Relay Board, and Control Board. I would also recommend doing a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 01, 2015 | Electrolux 36" Electric Hybrid Induction...
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
I was boiling water for potatoes on the Electrolux induction cooktop last night. Only using one of the five burners when I heard a "pop" sound and possibly a flash of light. Error code we have is EO
Hi Gail, I am happy to assist you!
It appears the main control has detected a faulty or error condition. "E0" should be followed by two more digits to indicate which error has occurred. Let's try turning electrical power supply off. It is necessary to wait roughly ten minutes to reset cook-top main controls. If resetting the power does not correct the issue or provides a new error code, at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Dec 20, 2013 | Electrolux 36" Electric Hybrid Induction...
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
Electrolux Induction Cooktop E36IC75FSS Error Code 41
Hi Sue -- when you switched the breaker, how long did you leave it off before switching it back on? Generally, it's a good idea to leave the breaker off (or unplug the unit) for a full 30 seconds before switching the unit back on. If you did have it off for 30 seconds and the error code came on after that point, then it may possibly be a relay isse. That will more than likely require a visit from an authorized servicer to properly diagnose the cooktop. Hopefully the 30-second test prevails and the issue is resolved. Best of luck!
Aug 27, 2012 | Electrolux 37 in. Designer Series...
ELECTROLUX ERROR CODE E95
Verify AC input voltage at the cooktop input. Verify AC main input cables, screws and jumpers. Verify the fuse resistance to be approximately 0 ohms on the Induction Module. Replace the Filter Board on the Induction Module.
Aug 07, 2012 | Electrolux 30" Electric Hybrid...
One plate in Bellini induction cooktop continues to flash with a pot on it, yet the pot works on the other 3 plates. How do I fix?
Had the same problem after overusing one of the bigger elements on my bellini induction stove / cooktop to boil copious amounts water. Element eventually stopped working and would just flash power level similar to when it cant recognise an induction pot, but also made a clicking noise over and over. My solution was to turn mains power off at meter box, and back on to reset the stove. When power came back on stove was working again! might have reset some sort of cutout sensor inside stove but cant be certain. Anyway, worked for me so give it a go and see if it helps. good luck.
Feb 13, 2012 | General Cooktops
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 | Cooktops
Kitchen Ranges Logo
1,628 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
