Question about Hitachi RAS-09UH Air Conditioner
HITACI SPLIT SYSTEM
Is there an online user manual for the split system? We can't work out how to set the heating component and have no idea where the user manual that came with the system is.
Thank you
Meryl Todd
Thank you
I found the solution by going to HItachi web site and clicking on a deleted model manual. It was basically the same set up and worked
Posted on Jun 24, 2008
    Novelist:
    Champion:
  • 230 Answers
Without a model number I can not do much leg work for you. But you can email them direct here inverterinfo@hal.hitachi.com
This link may also prove to be of some help getting the documents that you need. http://www.hitachi.us/Apps/hitachicom/content.jsp?page=Inverters/Support/index.html&level=2&section=Inverters&parent=Support&nav=left&path=jsp/hitachi/forbus/powerequipmentsystems/
Posted on Jun 23, 2008
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Where are the heat strips on a rheem classic 10 seer heat pump
3 Ton Heat Pump Split System ' eBay
www.ebay.com/bhp/3-ton-heat-pump-split-system
eBayGoodman 3 Ton 14 SEER Heat Pump Split System GSZ140361 with Installation Kit.10k Heat Strip,Thermostat,Wiring, Disconnect Box,Pad. $1,912.00; Buy It ...
Jul 28, 2015 | Heating & Cooling
What is the split pump
A split system has the parts split up between indoors and outdoors. A heat pump heats and cools your living space with the same unit. A split heat pump has the system split between indoors and outdoors and heats or cools your living space. a SPLIT PUMP sounds like something that has broken.
Feb 01, 2015 | Heating & Cooling
Emergency heat not working where is the heating elements located
user manual:
javascript:openreq('http://downloadcenter.samsung.com/content/UM/200305/20030520185350656_AS18A2RE.pdf')
if you are using a hard wired thermostat, you have one designed for a heat pump. Heat pumps are minimally effective at outdoor temperatures below 30'f. Emergency heat systems are not generally included with any split system, but would be located in the indoor air handler.
Nov 19, 2013 | Samsung AS18A6RB Air Conditioner
Hello We just installed a Sanyo KHS1271 mini-split
The condensate drain line was not properly installed. Make them pull the wall unit and correct the problem.
Be persistant until you are satisfied they have the problem corrected. Do not pay any additional money. If they do not correct the problem then report them online to the state board of heating and air. Fill out their requested complaint form and follow thru with a second complaint if you do not get total satisfaction from the contractor that installed the unit.
Hope this helps.
Sep 23, 2011 | Sanyo Split System Air Conditioner
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
Jun 15, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Is a split a/c alc and a heating or heat pump?
a split system can be gas or can be a heatpump. a split system is when the condenser coil compressor and outdoor fan is outside. the other half is in the house close to your air filter .that well be your air handler. eletric heater. or gas burner .and indoor fan motor would be. i hope that helps you.
Apr 15, 2010 | Cfm Daikin R410a Split System Air...
Split not cooling and not working on heat
make sure outdoor unit is running if it is may have low freon if not check power at outside unit
Aug 25, 2009 | LG LS092CE Split System Air Conditioner
How to make the heater work on the air con in the house split system no user guide its cold
set the thermostat on a higher setting turn it to heat position if that don't work thermostat may be bad. Good luck Tom
Jun 27, 2009 | Heating & Cooling
Hitachi RAS-09UH Air Conditioner Logo
467 people viewed this question
Top Hitachi Heating & Cooling Experts
rugby prop
ka4iup
ka4iup
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
