Question about HP f2105 21" LCD Monitor
OSD lock out
Monitor keeps flashing osd lock out
  • 5 more comments
  • compguy1 Jun 22, 2008
    When I turn my computer on, my monitor keeps flashing OSD Lock out followed by main menu and then repeats the cycle again. It doesn't turn off with the power button, none of the buttons work.
  • Anonymous Jul 19, 2008
    osd loc etc keeps flashing
  • Anonymous Jul 29, 2008
    OSD lock in the middle of the monitor screen. Really annoying. Tried the menu ten second thing... Works for like two seconds before popping up again.
  • joeff203 Oct 27, 2008
    i have the same problem and still here any idea guys..its anoying greeeeeeeeeeeeeee
  • Anonymous Mar 21, 2009
    I have the same problem,"ods lock out"in the middle of the monitor screen. Someone can help me?
    I have the same problem,"ods lock out"in the middle of the monitor screen on my compaq fp 5315. Someone can help me?
    I have the same problem,"ods lock out"in the middle of the monitor screen. I tried to fix it by main menu's button but doesn't work.Someone can help me?
I HAD THE SAME PROBLEM BUT ALL THAT WAS WRONG WITH IT WAS THAT MY MENU BUTTON WAS STUCK, TRY MESSING WITH IT BY FLICKING IT OR JUST MOVING IT AND IT WILL PROBABLY GO AWAY
Posted on Nov 28, 2009
On my monitor it was a stuck 'menu' button. I 'flicked' it with my fingernail and the problem went away.
Posted on Apr 25, 2009
I HAVE AN OSD LOCKOUT ON MY SCREEN WHICH BRINGS UP THE MAIN MENUE. THE MOUSE DOESNT WORK ON IT TO SWITCH IT OFF!!
Posted on Mar 17, 2009
I am having the same problem, i opened up the monitor ( very easy) and checked the swithc board to see that all buttons arfe working. Ang movrd all of my ( i have about 15 things attached to the computer) gadjets far as possible ( maybe it wasn't shilded properly). As far as i know i am using it for over an hour now and it hasn't falsed the osd locked out yet. I will post again if this goes away for good
Posted on Jul 29, 2008
SOURCE: OSD Main Controls Locked
Hold the "OK" button for about 20 seconds
It will initialy come up with the message "OSD Locked" and then after the 20 seconds a ne message will appear "OSD Unlocked"
Posted on Jan 19, 2009
efs_perpends
  • 1996 Answers
SOURCE: OSD LOCK
You are having a problem with the OSD lock on your ViewSonic Monitor. Is that correct?
If so, please follow these instructions to unlock or lock your monitor.
On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD
Please let us know if you require any further help with this matter.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Mar 31, 2009
SOURCE: osd main controls locked/unlocked pops up every 5 seconds
Estava também com o mesmo problema de voces, já estava irritado, então abri o monitor e desconectei a ligação com a placa de controle dos comandos dos botoes do menu. é fácil fazer. Só que não vai funcionar mais os botoes. pelo menos essas mesagens não vão mais incomodar.
Posted on Jul 18, 2009
yboyandrei
  • 828 Answers
SOURCE: Compaq FP5315 monitor with OSD Lock out
Here is the tip to solve your problem. Hope this might be helpful to you.
OSD Lock—The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message “OSD Lock” displays for five seconds.
❏If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
❏If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Posted on Aug 07, 2009
  • 156 Answers
SOURCE: HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Posted on Nov 30, 2009
My monitor is eperiencing OSD locked and it keeps on popping out the screen. how do i fix it?
Hi rimandopaolo,
I see that you are getting the OSD locked pop up on your screen.
Press the Menu button on your LCD monitor look for the OSD option on the menu once pressed selct the OSD option try to see if it will give you an option to unlock the OSD setting on your LCD monitor
I hope this helps.
Have a nice day,
mvincentc
May 11, 2011 | Hannspree HW191D LCD Monitor
Hi, I have a Samsung 940bw monitor. Somehow, it got locked. How do I unlock my monitor? Thanks.
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Feb 06, 2011 | Samsung Syncmaster 940BW LCD Monitor
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
plz do rate the solution if helped
Nov 22, 2010 | HP L1506 15" LCD Monitor
Why am I getting osd main controls locked flashing and then the same message saying unlocked and i am unable to clear it - posted in Monitors ... the attention osd locked is constantly flashing on and off...
Most of the monitors have a function to lock the OSD to prevent accidental changes in the configuration of the monitor.
If you are constantly getting the message about OSD being locked and unlocked then it means that the OSD locking button is constantly pressed.
Usually it is the "Menu" button on the monitor which is used to lock the OSD.
Check if the Menu button is constantly pressed.
Sep 11, 2010 | Compaq Presario 5000 PC Desktop
OSD lock flashing on monitor
To remove the OSD lock, kindly use the steps as shown in the attached image:
Hope this solves your problem. Thanks for using FixYa.
Jun 14, 2010 | ViewSonic E70f (White) 17 in.CRT...
OSD LOCK
Normally the OSD lock will only be displayed for 5 seconds.
Regardless you should be able to get rid of it by pressing holding the up arrow key for 10 seconds.
If this fails to resolve the issue try this. Disconnect power cord. Now press and hold button 1. Plug the power cord back in. You may have to press the power button while still holding button 1. The OSD lock should clear after that.
Hope this helps.
Oct 02, 2009 | ViewSonic E70f 17" CRT Monitor
Philips monitor 190b6cb/175
Same problem OSD main controls locked the 5 seconds later OSD main controls unlocked then system closes down sayingproblem with atkdisp, what does all this mean? Can still operate my computer but thid damned flashing OSD message continues.
Aug 10, 2008 | Philips 150S4FB 15" LCD Monitor
AOC 7 F 17" the OSD keeps on flashing
DIAGRAMA DE CABLE VGA DE MONITOR AOC MODELO F1770 DE FABRICACION O MONTAGE EN CHINA
Aug 03, 2008 | AOC 7F 17" CRT Monitor
HP f2105 21" LCD Monitor Logo
1,209 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
