SOURCE: Lexmark X1150 only prints first page
I have an x4550, running windows vista basic on an hp dv6000t notebook. i had the same problem. i contacted online lexmark tech and here's the solution that worked for me, thanks to help from lexmark (transcript of chat):
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. It should be set to the default to "LEMF." Change it to "Lexmark." Under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
SOURCE: Lexmark X1150 driver for that vista computer doesn't print in color
Download the Lexmark X1150 driver at the Lexmark site here:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1019285789_0_en,00.html
Dr.Luiji
SOURCE: how lexmark x1150 is compatible with windows vista
Your printer is compatible, you need to download and install updated software, see here: Windows Vista Compatibility Lexmark Lexmark X1150
Also unplug printer usb cable before installing drivers, and start installer file using right mouse button click, and then the option 'Run as administrator. Also disable antivirus/firewall before installing.
SOURCE: Lexmark x1150, set up printer on new computer
Hope this help. Please Rate My Response! Thanks!
Prem
SOURCE: My Lexmark x1150 printer prints blank pages.
Usually, when the printer prints, but the page comes out blank, the print head on your cartridges is clogged. Since you pointed out that you computer was repaired, I guess you weren't printing during that period, so it is quite normal that the cartridges won't print. Here is a link to Lexmark's site.
http://support.lexmark.com/index?page=content&id=HO1562&actp=search&viewlocale=en_US&userlocale=EN_CA&segment=SUPPORT&productCode=LEXMARK_X1150&searchid=1270554483928.
Read carefully and follow the instructions. If necessary, do several nozzles cleaning, but do bear in mind that it uses a lot of your ink.
If you found my answer useful, please vote and leave a comment, that's what makes it all worth while!
