Washing machine DRUM NOT TURNING indesit wdg985w
This machine has had very little use, the drum will not spin on any cycle, you just hear the water pump.
I have tried and checked the following:
Drum is not siezed spins manually OK
Belts in place
Checked for bushes worn they are 1.5 inches long loads of life left!
Checked wiring and plugs for loose and bad connections, there ok
Checked for dry joints on main circuit board.all good..
Any help greatly appreciated, this machine belongs to my pensioner neighbour, who cannot afford an engineer
Please please help.
Thanks kindly
Bal
  • 38 Answers
The lid switch is bad.
Posted on Jun 22, 2008
I have an Indesit washing machine and when it get to a fast spin cycle it sounds like it is washing a load of rocks. It is very loud. It doesn't seem to do this when the drum is turning slowly.
Hi.
It soumds to me like the main drum bearings have failed.
From the front of the washer, put your hand inside the drum and spin it round, it should be noise free, if it feels rough or is grating or rumbling, then the bearings have failed.
This is quite a big and involved repair to undertake.
Feb 06, 2011 | Washing Machines
I have a indesit WIB 101 (uk) washing machine.
Remove the belt, and from the front, spin the drum by hand.
If it is noisy or rumbling or feels rough, then the main drum bearings have failed which would explain why the belt was off.
Also check the drum pulley for a brokem or cracked spoke, again this will give you the same symptons.
Please rate my solution.
Thankyou.
Jan 13, 2010 | Washing Machines
Indesit wdg985w water licking. is anyone help me how to fix it please?
there is a hole in the drum, mine did the same. I had to weld it and then use a metal filling compund to seal the hole
Dec 15, 2009 | Indesit W 123 Front Load Washer
DRUM WILL TURN TO EITHER WASH OR SPIN CLOTHES
your belt has probably fell off the back of the drum try turning the tub by hand see if you can hear the motor turning with it
Mar 31, 2009 | GE WSXH208A Front Load Washer
Indesit wd125 drum wont turn
check your pump it may not be working
Dec 18, 2008 | Indesit W 123 Front Load Washer
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
My indesit WG1230 washing machine does not spin or move drum but water go in and out.
With the door open, try spinning the drum, there should be some resistance along with a slight wherring sound. If it spins freely without much sound at all - you probably need a new belt.
If you can feel it driving the motor, you may need new contact brushes for the motor.
If the machine buzzes when it should rotate on program, you need a new motor Run capacitor also.
If no sound - nothing, the motor may need replacing or at least checking.
Nov 05, 2008 | Indesit Washing Machines
Indesit WD11
is the drum turning round. is it draining at end cycle ? if the motor is spinning is it slow at start turning left then right after a time or does it just spin when its on spin cycle ? can you hear a clicking sound when it about to move or hear a clicking sound and nothing moves ? if you hear a clicking but nothing is moving it could be the switch on the main board has worn out, it could even be the motor but if it does a spin it could just be the switch on the main board. they soldered in on the board you can replace them if you have soldering skills or would like to learn.
Jun 22, 2017 | Indesit W 123 Front Load Washer
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
494 people viewed this question
Top Washing Machines Experts
