Cars & Trucks Logo
Posted on Nov 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2003 yukon rear wiper motor wont work makes loud noise and no movement even after i changed the motor is this a switch problem
Anonymous
Level 3:
Brigadier General:
  • Master 7,353 Answers
  • Posted on Nov 24, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
7353
Questions
Helped
2487150
Points
23804
If it makes noise when you turn it on, the switch is working. So whats making the noise. If you replaced the motor, there isnt much else. Is the wiper arm tight on the shaft?
We recently had an icestorm now my windshield wipers make a loud noise and wont work
If you turned the wipers ON while they were still frozen to the windshield you likely stripped the gears in the wiper's motor. They're likely only going 1/2 way because the wipers also got misaligned on the motor shaft, too.
You may get lucky and be able to REALIGN the wipers on the shaft.
Watch this video: https://www.youtube.com/watch?v=c-tR49oL1FQ
for an idea of what I mean.
GL,
TD
2005 gmc yukon rear window motor buzz, new one does same thing
sounds like you may have a bad ground on the motor .even a brand new motor wont work if it has a poor ground check your connections
On my 1998 ford contour my windshield wipers wont work and a loud banging noise is happening even when they are off
It sounds as if the wiper linkage has come adrift, normally will require renewal of a link arm
1helpful
Rear wiper motor has power won't wipe 06 gmc yukon,makes a ticking noise
if you have power to the motor and it still is not working then I would say that the motor itself is bad and at fault. replace it and all should be good.
c...
1helpful
2answers
I have a 2003 GMC yukon, the rear wiper does not work,the fuses are good, what should I look at?
JUST PUT A NEW GROUND WIRE TO THE REAR WIPER MOTOR............SIMPLE GOOD LUCK
Windshield wipers in front wont work but rear wipers work
Hi! U need to check the switch and the wiring circuit that controls the motor.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
