Question about Frigidaire FGB24S5A Gas Single Oven
Why won't my oven heat to the proper temperature? It takes forever for our oven to heat up to the proper temperatures. My gas bills have skyrocketed due to this issue. I am considering going to electric because of this. HELP!!!
  • 2 more comments
  • Anonymous Jul 14, 2008
    the light preheat is on but never is ready it take forever and never is ready
  • martinezluis Jul 14, 2008
    preheat light is on but it takes forever
  • 7656 Jul 15, 2008
    The problem with the temperature not reaching the set temp is not just a gas stove problem. We have a model ES200 electric and it's doing the same thing. Help Anyone? Is it the temperature sensor or thr thermostat?
  • Anonymous Mar 12, 2014
    electric oven not heating to temperature and sparking in the oven
    Scholar:
  • 93 Answers
All these problem related to temp sensor or thermostat. check your wire harness for proper connection. or change your temperature sensor.
Posted on Jul 25, 2008
Oven won't heat to temperature
Does it reach the temperature and then back down, or does it take too long to get to your set temperature? Either you have a faulty element or a bad communication error with the main control board.
Sep 03, 2012 | Frigidaire FGB24S5A Gas Single Oven
BXA2G oven is not heating properly and also air-flow on display board is not stablising and also both set temperature and oven temperature is flashing.so can you email me aa manual please
Your temperatures will begin flashing after the oven attempted to heat for 10 minutes without successfully increasing in temperature. Sound like you are having burner issues and should call a licensed burner technician to have it serviced.
Aug 05, 2011 | Baxter BXA2G Stainless Steel Gas Single...
Oven is taking forever to get to the proper temperature.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 05, 2011 | Ovens
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
GE wall oven
Hi Den3,
Are you sure that you have not inadvertently switched to the Celsius temperature mode? A temperature of 282 degrees C corresponds to 540 degrees F.
I doubt that it is the heating element. They either fail by short circuiting or by opening up completely.
Regards,
Powerman
Sep 15, 2008 | Ovens
Frigidaire FGB24S5A Gas Single Oven Logo
369 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
