Question about Hitachi 32HDT20 32 in. Plasma Television
Hitachi 42HDT20 Blinking orange light
I have had this plasma for about 5 years with no problems. All of a sudden the standby light is flashing orange which the manual states the monitor is on but is receiving no signal from the AVC(audio/video control center). This unit seems unaffected (light will change from red to green when turned on). I unplugged all of the cables waited a few minutes and then reattached. The blinking stopped and the standby was red. I turned on the tv and a show popped up on the screen for about 20 seconds. The set turned off and the orange light blinking resumed. Does anyone have any suggestions?
3 Suggested Answers
Basti
  • 1447 Answers
SOURCE: 55hds69 hitachi plasma
First, try the unplug it, wait a few minutes, plug it in trick, several times. If that doesn't work try pressing the power button and slap the back left side of the set several times. Sometimes, this will shock the ballast and/or lamp into working.
Try checking the wires as well if its pinch or not and try to take out all cables from other devices from the back
Posted on May 14, 2008
Slinteriors
  • 8617 Answers
I have had some issues with high ESR readings in the capacitors in the scaler circuits in those units. Do you have an ESR meter to check the caps in circuit?
Posted on May 16, 2008
Hitaci plasma 42hdt20 remote will turn monater when red standby light on
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://electro-medical.blogspot.com/
Dec 25, 2016 | Hitachi 42HDT20 42 in. Plasma Television
Hitachi plasma tv
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 28, 2015 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi tv won't turn on, only flashing orange and blue light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 27, 2014 | Hitachi Televison & Video
Flashing orange light what happened?
Unplug it for a while, pray a bit and then plug it in again while keeping your fingers crossed.
Jun 02, 2014 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Hdmi
You can get HD using "Component" video connections.
Geno
Mar 17, 2008 | Hitachi 42HDT20 42 in. Plasma Television
Screen does not switch on, mode light flashes orange
Need to remove the Input module circuit box from the bottom of the center and wait for few minutes before putting it back.
This will reset the system from this persistant power off problem.
Best way to prevent it from happening again is to manually switch of the power switch before doing any powering off and on. Most commonly happens during a power failure and power coming back on with the switch in the on position.
Oct 02, 2007 | Hitachi 32PD3000 32 in. Plasma Television
Hitachi 32HDT20 32 in. Plasma Television Logo
358 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
