Question about Onkyo TX-DS777
Onkyo TX-DS777 Problem
No power, when standby/on button pushed on receiver or remote. Power button turns on the standby light. AC fuses checked good. Please help!!!
Man I think i have the same problem....
i push the power button but immediatly the LED turns off. I cheked the fuse but thats not the problem. Please if you solve your problem let me know...
my e.mail adress soy_robertog01@hotmail.com
sorry if you dont undersatnd me in some parts..im not very good writting english haha sorry..
Posted on Jul 29, 2008
Onkyo TX-DS777 does not retain settings after power loss
No internal battery, a large "SuperCap" on the main board acts as one. Look for C8007, 0.1 F, 5.5V.
Apr 26, 2010 | Onkyo TX-DS777
Cannot turn on by remote controller. Want to
Ok, here is my little spin on remote controls.
Sometimes they can be overloaded with commands and lock up the processor that is inside the unit.
The remote can be saved.
1. Remove the batteries and press every button on the remote control and then install new, not the batteries you took out, but new batteries and see if that works.
2. If step one does not work, then you can remove the batteries and unfold a small paper clip and bend it into a U shape and use it to touch the contacts on both ends of the battery contacts together and clear the memory.
3. Test the remote control, if you have a camcorder or a digital camera, and a cell phone will work. Point the remote at the device and press any button, you should be able to see the IR (Infrared LED) lighting up on the display.
If after all of these procedures are followed and you still do not have command of the device that you need to control. You still have more options.
Either replace the remote control with a new or compatible one, I use 1-800-remotes, www.remotes.com.
Or have the device that you are trying to control diagnosed by a technician and see if the remote IR receiver in the unit has gone bad.
I hope that this helps you with your remote issues and as always, Thank you for using FixYa.
asnowman
Mar 16, 2010 | Onkyo TX-DS777
Power problem
Danny,
It may only need to be reset, unplug it for a min. plug it back in and try it.
Check your owners manual some will tell you how to reset them.
Also check for a jammed switch, press every switch one by one if one doesn't move that is the problem, you can possibly unjam it with a small screwdriver.
But it could need servicing.
Jan 23, 2009 | Onkyo TX-DS777
Onkyo tx-vs515pro won't turn on
doubt that reset will fix your problem---but here it is if you want to try:
hold down the cd button and press the power button [at the same time]
test will [should] appear on screen for about 5 seconds--you need to unplug the set during this 5 second period. this resets the cpu chip.
hope it helps solve your problem.
barnesmar
Nov 10, 2008 | Onkyo HTR500 Receiver
Will not power up but stand by light is powerd up
I have onkyo tx-ds575 and i need to conect it to my tv and have audio from a LCD flat panel.
Oct 05, 2008 | Onkyo TX-DS575 Receiver
Onkyo 870 relay problem?
do you have speakers hooked up on B?
Jun 26, 2008 | Onkyo TX-DS777
Tx-ds777
Same thing happened to our TX-DS777.
Took it to a locate electronic comany and they told us it was the
DSP board gone bad. Est 425.00 to 450.00 to fix.
Aug 16, 2007 | Onkyo TX-DS777
Power light on, unit will not turn on with push button
When power was intermittant, were there any other discrepencies or audible power deprivation to the speakers? Your problem has many possibilites from fuses to major amplifier problems to common power supply failures. Being intermittant then dead may still be a simple fix, but not without some physical intervention of test gear. Sorry, Jaszy
May 30, 2007 | Onkyo TX-DS777
Onkyo TX-DS777 Logo
337 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
